Old 05-01-2005, 12:30 PM   #1
Rich Druash
Rich Druash is an unknown quantity at this point
getting slower as I drive
When I first start driving my car it runs pretty strong, but after 20-30 minutes it gets slower and slower. If I drive it hard it will get slower after only 5-10 minutes. The other night after racing a mustang my turbo was glowing red. I checked my timing and when I set my gun at advance 14(stock), it lines up with the timing mark all the way to the right on the crank pulley, If I set the gun at 0 it will be a good amount to the right of the last timing mark to the right. Is this timing off? Could my turbo be going bad? I've had 3 turbo cars and never had any problem like this. It seems like the engine is getting too hot, but the temp guage says it's cool. If anyone can help me with this I would really appreciate it.
----my set up
redtop sr20
greddy vspl front mount intercooler
hks exhaust
trust downpipe/turbo outlet/ catco racecat
spec stage 3 clutch
walboro 255 fuel pump
runing 12-13 pounds of boast with no fuel management
Rich Druash is offline   Reply With Quote
Old 05-01-2005, 01:06 PM   #2
[GoaTSLonG]
[GoaTSLonG] is on a distinguished road
13psi on stock injectors is a no no
WRECKED.
[GoaTSLonG] is offline   Reply With Quote
Old 05-01-2005, 03:34 PM   #3
WeldingHank
WeldingHank is an unknown quantity at this point
sounds like your timing is wayyyy off.
1989 240sx:CA18DET
My Cardomain
WeldingHank is offline   Reply With Quote
Old 05-01-2005, 04:01 PM   #4
S14DB
AFC #1
S14DB's Avatar
Your timing is fubar and your spraying fuel into your turbo and it's burning there.
Old 05-01-2005, 04:34 PM   #5
kandyflip445
kandyflip445's Avatar
kandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfection
Send a message via AIM to kandyflip445
Heat soak!!!!
My 240 vBgarage
kandyflip445 is offline   Reply With Quote
Old 05-01-2005, 06:07 PM   #6
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
you did disconnect the tps sensor when you check the timing correct? im almost positive you must do this
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 05-02-2005, 10:45 AM   #7
Rich Druash
tps sensor
where is the tps sensor, I'm not used to timing coil packs
Old 05-02-2005, 11:30 AM   #8
TheSparo
it stands for the throttle position sensor, it is right around the throttle body, near the butterfly if i remember correctly
Old 05-02-2005, 08:40 PM   #9
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
15 degrees is the second mark from the right. Set it there and see how it goes.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
