Here's the scoop, the key doesn't work in the slot because it's siezed, which is no biggie, but just this afternoon, the release lever beside the driver seat stopped working. When I pull the lever, I can see that the latch still moves, so the cable is in one piece. It's hard to reach through the rear seats to work on the #### thing though. has anyone ever had this problem?? And how did you fix it?? It should be easy enough, but I don't want to torque on the latch and break it...guidance please!!
Yeah, that's what I plan on doing to the lock itself, but what about the release latch? I've tried reaching in and moving it around, but it doesn't seem to want to move to the left far enough to unlock the trunk?
![]() Join Date: Jul 2001
yea and after you open it there is this little metal bar... press it down and both will work... my cable stopped working so i had to open it with the key and in the latch hole there is a bar you can press down to make it work again
I've tried doing that with the latch, I can move it up and down about 1/4inch or so, how far should it move? And when it is fully pressed down, should it click firmly into place? Because when I try to pull it down, and then use the trunk release, it snaps back up, so am I not pulling it down far enough?
My friend had this problem in his 95 Base. Luckily one of our friends is really tiny and crawled into the trunk and unlocked it. There's a lock or something on the inside that accidentally got triggered. Hope this helps.
