Old 08-21-2010, 08:54 AM   #1
BoxMan
BoxMan's Avatar
BoxMan is an unknown quantity at this point
Lightbulb Still No Dash Light
I've been trouble-shooting this for a while now on my '89 s13 coupe and I've been all over nico already trying to solve this issue. I turn the lights on at night and everything works but the dash light. And I mean everything else works, so that rules out things like the fuses (checked and replaced) and the TCU ( manages the climate controls, dash light, and glove box light; climate controls and glove box both work) It's not the bulbs behind the dash, I've checked those. And the cluster is secure to the harness; no faulty wires or hanging plugs.
The cluster itself WORKS! All gauges work like they're supposed to. All the little lights work too ( oil lamp brake lamp seatbelt lamp etc.)
ALL exterior lights function the way they're supposed to. There's pretty much nothing else that doesn't work. Just the dash light. This is really weird.
Help me out?
Bone in and Bone out!
BoxMan is offline   Reply With Quote
Old 08-21-2010, 08:28 PM   #2
nippon240
nippon240's Avatar
nippon240 is an unknown quantity at this point
I had that same problem, and It was the TCU
nippon240 is offline   Reply With Quote
Old 08-21-2010, 08:58 PM   #3
Hxc_Nismo
Hxc_Nismo's Avatar
Hxc_Nismo is an unknown quantity at this point
did you check for voltage at the pig tail behind the cluster to see if you were even getting a 12v reading for the dash lights and if you did, did you simply just check the bulbs in the cluster to see if they were blown???
Hxc_Nismo is offline   Reply With Quote
Old 08-21-2010, 08:59 PM   #4
BoxMan
BoxMan's Avatar
Ah, yeah see that's the thing! If my TCU were fried, my glove box light and climate controls would not be working... and they do. :/ Should I swap the tcu regardless? It wouldn't hurt...
Old 08-21-2010, 09:01 PM   #5
BoxMan
BoxMan's Avatar
No, I did not check for a 12v reading, however, I checked the bulbs and they're fine. I even replaced them all just to make sure. Still no illumination.
Old 08-22-2010, 07:53 PM   #6
spoolandslide
i got the same problem however I haven't even bothered to check it out. I just use a little color changing led light to check my speed at night. otherwise I don't really care ahaha
spoolandslide is offline   Reply With Quote
