Old 02-24-2020, 05:53 PM   #1
Alex_Zenki
Alex_Zenki is an unknown quantity at this point
Ls1 psi conversion harness
Just bought a belt LS1 and t56. It came with a psi conversion standalone and was tuned on it. Can I run this harness and computer in my s14 Without a crazy amount of alterations. Or is it just better to go the wiring specialties route
Alex_Zenki is offline   Reply With Quote
Old 02-25-2020, 04:30 AM   #2
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
So, you're asking if you can run an ls1 harness on your KA? Or asking about doing an LS swap on your chassis using that harness? I assume you mean speed density when you're saying 'psi conversion'.
To the first question, no, that isnt going to run a KA engine. V8/i4 way different. To the second you may be able to use it for an ls swap. I say MAY very openly, not sure what chassis the harness is coming out of.
NukeKS14 is offline   Reply With Quote
Old 02-25-2020, 05:12 PM   #3
Alex_Zenki
Had a typo in my initial post, built* ls. I have pics of wht I’m talking about I’ll upload later. The psi conversion is. Full harness and stand alone. Come out of a 69 camaro that didn’t have any stock wiring. Dash and all electronics were wired through the harness or were simple gauges
