Old 09-11-2013, 12:35 PM   #1
rhdsilvi85
rhdsilvi85 is an unknown quantity at this point
s13 jdmcc help!! (inside)
ok, so new knowledge found... so I have an s13 with jdm wiring, just realized I have a anologe subharness fml I thought it was the jdm digital cc harness so my question do I need to go and re get the digital harness? or can I make due with what I have and do some depin and moving of wires to make work? I have another jdm cc digital harness but its trashed so i'd have to redo all the wiring on it to make it work..
thanks guys
this is a link to what my harness looks like
http://hardtuned.net/forums/index.ph...tach_id=324689
rhdsilvi85 is offline   Reply With Quote
Old 09-11-2013, 01:22 PM   #2
Mikester
Mikester's Avatar
Mikester is a well-known jackass
^^So essentially, what you're saying is that when you provided the system a ground, things started working... If I were you, I'd make sure all the grounds are good.
Mikester is offline   Reply With Quote
Old 09-11-2013, 01:31 PM   #3
rhdsilvi85
well that's the thing unless a ground is wire is bad.. I rechecked my grounds ground down the spots they were located at... I mean physically the jdmcc is showing everything the way it supposed to but yet doesn't work function wise..
Old 09-11-2013, 01:32 PM   #4
rhdsilvi85
before it just didn't even work lol
Old 09-11-2013, 01:34 PM   #5
rhdsilvi85
do you know if the fsm for s14 digital is same as s13? ive been trying to find wiring diagrams but have been having a lot of issues since it's the real 180sx wiring
Old 09-11-2013, 01:36 PM   #6
Mikester
Mikester's Avatar
There is:
Blower motor resistor
Sunload sensor
Blend door actuator
Ambient air temp sensor
Cabin temp sensor
I assume you have it all?
Wiglle the wires near the backs of all the connections... Maybe something is tweaked.
Old 09-11-2013, 01:43 PM   #7
rhdsilvi85
ill have to check that and continuity at the grounds to make sure there isn't a bad ground some where
Old 10-24-2013, 11:12 AM   #8
rhdsilvi85
new info please read top.. need help
Old 10-24-2013, 12:30 PM   #9
rhdsilvi85
any one have good pics of their jdmcc wiring subharness Im going to rewire mine... I have a jdmcc one that is bad so I need to see color codes to rewire
