Old 02-19-2018, 11:59 PM   #1
hoOzier
hoOzier is an unknown quantity at this point
Shifter for 1JZ swap S14
So I have a S14 swapped 1JZ (will be the same fitment to a 2JZ if anyone has built one of them) and I'm using a TR6060 transmission from a VE SS commodore, I need to work out how to get a shifter in there, I have seen some off the shelf shifters but they are like $500 and I'm running the risk that it doesn't fit with this swap, I'm desperately trying to find someone that either knows how to do this, or has built one them selves, what is the solution? did you go custom? did you go with a certain company?
The TR6060 is a newer stronger generation to the T56 so they are very similiar just with different mounting points for the shifter, so if someone has also done something with a T56 S14 such as an LS swap your input could help aswell.
thanks in advance
hoOzier is offline   Reply With Quote
Old 02-20-2018, 12:34 AM   #2
derass
http://zilvia.net/f/showthread.php?t=653845
1jz swap, ls swap, t56, tr6060
