Old 08-07-2015, 07:33 PM   #1
s13sr20z
s13sr20z is an unknown quantity at this point
S13 headlights don't go down?
Motors are working (tested them), lights go up with switch (dash) but not down, changed the switch (dash) but that didn't help..any ideas? Thanks
s13sr20z is offline   Reply With Quote
Old 08-14-2015, 10:46 PM   #2
mastadon
mastadon is an unknown quantity at this point
Try cleaning/ repairing the headlight/turn signal stalk switch or replace it entirely. Could also be a relay issue. There are three relays in the drivers side of the engine bay behind the headlight. Search google for your problem, there have been may threads on many sites detailing this issue.
mastadon is offline   Reply With Quote
Old 08-14-2015, 11:08 PM   #3
zombiewolf513
They do that when they get worn out
Old 08-15-2015, 08:25 AM   #4
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
Still could be the motors. Mine did exactly that - up but not down, and it was a bad motor.
blkvrtswp is offline   Reply With Quote
Old 08-15-2015, 04:12 PM   #5
s13sr20z
did clean and replace headlight/turn signal switch, still not working, motors do work when wired directly to battery, will look into relays...thanks
Old 08-15-2015, 09:09 PM   #6
zombiewolf513
Your problem is the motors.
Old 08-15-2015, 09:17 PM   #7
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
do you have sleepy eye mod with a switch installed?
if yes - check cables connections at the switch or just connect the two wires there
cured13 is offline   Reply With Quote
