all these parts came of a 96 s14 unless stated otherwise. just have them laying around, so hit me up im located in moreno valley, ca
PM me or txt me at 714-858-4065 most these are OBO. Prices are without shipping, im willing to ship some parts at buyers expense. I got some nibbles and alot of flakers so plz don't waste my time, thanks ![]() Zenki le tails some minor scuffs n scratches.right has a small crack on the inside -40 ![]() open diff. did a gear oil change less than 500 mi. b4 lsd swap.perfect 4 welding(free .5 pint Mobile1) -40 ![]() Front calipers w/ lines and used sumitomo ceramic pads. No leaks -35 ![]() axles great condition no rips on the boots -40 ![]() rear dust shield -10 ![]() 4 lug rear hubs with good bearings(no rattle,spin good) -20 ![]() ![]() ![]() cracked rear bumper(fixable) -10 ![]() 3 base wheels w/ tires -15 each ![]() base damaged wheel - Free ![]() 4 lug rotor set -10 ![]() ![]() 5 lug front rotor -5 ![]() N/A Z32 Driveshaft(the 2nd half can be used if u have abs tryin to do a z32 vlsd swap) -20 ![]() z32 axles with no leaks and no tears on boots(lil rust from the moisture) -20 ![]() speaker board. No speaker grill -5 ![]() s13 HID blackhousing Lights one missing front glass(minus bulbs) -10 ![]() s13 oem side markers ![]() rear seats think these are off a 97/98 se?some sunfade on top,no rips -60 ![]() trunk hinges with tensions -5 ![]() rear bumper retainers? they help hold ur rear bumper in place -5 ![]() emerald green passenger mirror with working motor-10 ![]() Clutch fan with good bearings for sr or ka -15 ![]() stock rear sway bar endlinks for se with good bushings -10 |
PM me or txt me at 714-858-4065 most these are OBO. Prices are without shipping, im willing to ship some parts at buyers expense. I got some nibbles and alot of flakers so plz don't waste my time, thanks ![]() Zenki le tails some minor scuffs n scratches.right has a small crack on the inside -40 ![]() open diff. did a gear oil change less than 500 mi. b4 lsd swap.perfect 4 welding(free .5 pint Mobile1) -40 ![]() Front calipers w/ lines and used sumitomo ceramic pads. No leaks -35 ![]() axles great condition no rips on the boots -40 ![]() rear dust shield -10 ![]() 4 lug lubs with bearings(no rattle,spin good) -SOLD ![]() ![]() ![]() cracked rear bumper(fixable) -SOLD ![]() 3 base wheels w/ tires -15 each ![]() base damaged wheel - Free ![]() 4 lug rotor set -10 ![]() ![]() 5 lug front rotor -5 ![]() N/A Z32 Driveshaft(the 2nd half can be used if u have abs tryin to do a z32 vlsd swap) -20 ![]() z32 axles with no leaks and no tears on boots(lil rust from the moisture) -20 ![]() speaker board. No speaker grill -5 ![]() s13 HID blackhousing Lights one missing front glass(minus bulbs) -SOLD ![]() s13 oem side markers ![]() rear seats think these are off a 97/98 se?some sunfade on top,no rips -60 ![]() trunk hinges with tensions -5 ![]() rear bumper retainers? they help hold ur rear bumper in place -5 ![]() emerald green passenger mirror with working motor-10 ![]() Clutch fan with good bearings for sr or ka -SOLD ![]() stock rear sway bar endlinks for se with good bushings -10 Last edited by s141996; 01-18-2011 at 04:22 PM.. |
