![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
can u run a tuned ecu on stock motor?
ive been searching but really havent found a true answer
i understand it wont run completely right....but the ecu is tuned for 550,z32 maf, and 2871r turbo i have 370,z32 maf, stock t25 would it make it want to run lean? |
I tried my friends ecu that was tuned for similar plus cams.
It was an emance ecu My car would turn over and over and eventuallly fired up and ran like complete garbage for 2-3 seconds then died. I have stock eveything. From that i would say no.... Your z32 mafs probably makes the biggest difference in compatability. |
![]() Join Date: Mar 2008
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
depends on the ECU. like a AEM EMS, you can easily set to stock calibrations with a laptop.
a chipped ECU is harder. probably need to find a tuner who can.
http://squarespokes.com/ |
![]() Join Date: Feb 2011
biggest thing is your injectors and maf, so since your injectors are different, it will run lean unless you adjust for it with a fuel pressure bump, but even then thats not a great way of doing it
Man w/ CTSV & a Car Seat
Why dont you just get the ECU rechipped?
PS: 550cc injectors are too small for GT2871R if thats what you plan on running later down the road. You'll need atleast 660cc injectors but most folks run 740cc since they're more readily available. |
