Fuel prime no spark. Ecu??
So doing an sr swap on my 240. First problem was I wasn't getting fuel prime now I fixed that but now I'm not getting spark I checked the CAS and the timing is all good but then I took an extra look at the ecu and saw this... Are those tabs important is there a fix or no I need a whole new ecu? Where can I buy one from a trust worthy person
![]() Join Date: Sep 2005
unless they are stopping the plug from fully seating they are not the problem or issue.
open the ecu up, look and smell. check the plug side for pushed out pins. go through the wiring again. make friends with people, borrow an ecu. if this is your first swap you probably missed the coil pack and/or head ground.
#4 | |
If he has an e5 or e6, should work fine, but definitely if you're just verifying spark.
Sent from my SM-N910T using Tapatalk
| ecu, no spark, sr20 |
