#61 |
![]() Join Date: Jun 2007
Just curious, when were you in Oki ?
Built RB25 - RB The World - Vertex Everything @RBVertexRidge |
#62 |
![]() Join Date: Dec 2006
04 to 07
meslgth
#64 |
nah Air Force
#65 |
![]() Join Date: Sep 2009
Very nice write up and very informative. I am in the same boat as you S14 with series 2 RB25 swap. I just need wiring, clutch pedal install, fuel pump, custom DP and misc. things installed. Let me know who will you use for the wiring job or who you would recommend.
#66 | |
Yury does good work, i had him do my SR harness 3 years ago. Never had an Issue And hes making new premade harness's, which is what ill be getting when they are completed
#67 | |
I've heard good things about his work, and he's been around forever, but heard that the wait times get ridiculous. Never used him myself (obviously).
#69 |
Yeah i know im already starting to get alot of PM's maybe I should charge ppl for PM's haha
#71 | ||
#75 |
Thanks guys for the comments.
Before I start I know i could get some Mishimoto single fans and mount them but i want the FAL's since they cover more surface area and the RB's need the cooling systems kept in check. So I got in my new condenser today, I figured Id replace it since I'll be reclaiming the freon and pulling it to install the the FAL's Plus seeing that 12 years of elemental damage isnt helping the cooling capacity Current condenser, doesnt look bad but the fins are worn pretty thin in the bottom plus the design is 12 years old New design more fins= more cooling So here is gonna be the tricky part, making the FAL's, condenser, and Koyo Rad fit up front without cutting the core support or anything drastic. Im not gonna lie when it comes to me fabricating its not pretty, but damn it, it will work haha. so from the bottom of the lower core support lip to the Koyo I have about 6.5cm (2.5 in) the New condenser is a little bit thicker Pretty much what im gonna do is mount the FAL's to the condenser and reloacate the condenser closer to the Koyo (these are Pusher fans) here is a side measurement (unsprung) looks like I have plenty of room but the bottom the FAL covers have a .5 mil lip there is a .5cm lip that is where the Lower core support lip will hit, Which makes it sit at about 6.0cm, I guess i could shave it down if needed But when mounted and pressure applied I can get it back down to 5.5 CM which will give me just enough maybe I know you need a little bit of space inbetween the condenser and Radiator but I think running a pusher I wont have to worry about it. But there will be about a 1cm space due to this outlet tube. hopefully I can start the swap next month if Jeff Jordan can do my wiring Harness (my harness is pretty fucked up)
#79 |
An Unrelated RB Update
Got a whole Z32 Brake Setup for $43 from a Junk yard in AL!! Cleaned them up and painted them Red Cleaned the Lettering My Agency Steel Braided lines will be here tomorrow, so if the weathers good then i can install them
#81 | |
Hell if there was more for the same price I would have taken them all haha
#82 | |
![]() Join Date: Mar 2010
#86 |
Dam what a clean thread you got going here!! Keep up the great work! And even killer deal on that junk-yard special, can't really beat that unless they're free lol..
#87 | |
Haha yeah i basically stole it
Thanks guys for compliments Right now im currently ATTEMPTING to wire my own Harness up, Since im tired of waiting on a damn harness. I really dont want to do this, since I hate wiring so well see how it works out. working on the M63 plug right now. Picked up a M63 plug from a Zenki (hopefully the pinout is the same as a Kouki) the straight wires are supposedly the only wires needed for the M63 Plug Heres the BS i gotta work with THANKS JDMONLINE.COM You Lying Bastards
#88 |
If you have any direct questions, I can try to help. I'm just slammed with the end of Formula D season and getting everyone ready for SEMA. Sorry Pat!
#90 | ||
Its cool man I understand. Quote:
Thanks Russell, Yeah been waiting a while and getting impatient. haha nah man your good Thanks Ugggghhhh I hate wiring, soo fucking tedious, Especially when all I have to go off of is wire colors instead of colors and pin location. My M63 plug is a little short so I had to use some extra wires and make them longer What i gotta work with.... I need a ESD Table FYI, I did not use Butt Connectors, Its soldered The red is just the heat shrink Pretty much done with it, I got 5 extra wires though, Im not sure what they are, I'll have to do some tracing tomorrow I think im missing a ground too according to my chart next will be the MAFS section.....sighhhh Fuck you JDMONLINE.COM.......
後輪駆動車1番1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online #/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 09-05-2010 at 10:17 AM.. |
| rb25 install, rb25 rebuild, rb25 s14, rb25 swap |
