![]() Join Date: May 2008
Chucks VH swap part out. LAME.
DEEP ASS DISCOUNTS 3/3/2014
Clearing out my garage from ALL this extra 240 stuff i have. Email me at [email protected] dot com for inquiries, or PM me. ![]() ![]() Hand polished VH45DE SII valve covers with brand new gaskets, chrome nuts, and brand new grommets. need about another 2 hours with a dremmel and some more polishing bits to be perfect all the way through. the center old red paint is covered with the coilpack covers, so i didn't worry too much about it. - $200.00 OEM VH45 front timing covers $50.00 SII VH45DE complete intake manifold with injector seats. all emissions crap has been tapped and plugged. egr is currently installed and ready to run on an S13. includes 94 manifold to engine metal gaskets. doesnt include throttle body. $60.00 ![]() OEM VH45 camshafts - good for a core? still in great condition - $20.00 VH45DE Coolant Y pipe / radiator inlet and outlet pipes with OEM new thermostat. includes OEM nissan blank off filler cap. $45.00 OEM VH45 Oil pump (as pictured)$50.00
Z32 Starter - in great strong working Condition. Definitely used condition though. - $60.00 OEM VH45 oil filter adapter to engine $25.00 Z32TT/VH45 Stage II XTD clutch, in Great condition, barely broken in. only about 500 miles on it. - $50.00 94 VH45 CAS - $25.00 VH45 VTC Solenoids - $20.00 for the pair **coilpack covers $15.00 each **coil ignitors - $30.00 for the pair both work perfectly S14 distributor - $50.00 KA/SR OEM shifter assembly - $30.00 -------------------------------- ========= SOLD ========== VH45 OEM crank pulley. No groove worn by the shaft from the seal. Sold S13 5-speed non ABS driveshaft - SOLD S13 KA24DE radiator (automatic) looks good. - Sold a ton of VH45 hydraulic lifters and rockers (about 40 of each)- SOLD KA24DE ACT??? stage 1 clutch barely any wear on clutch (cant proove its ACT) - SOLD OEM KA flywheel. doesnt even look used - Sold Z32 NA transmission with 4.08 speed sensor (perfect for S13 speedometer). Sold S13 front tension rods with energy suspension poly bushings already pressed in. doesnt include studs - Sold 8 ignition coils, that have been coated in liquid electric tape (regular mod done by RB2XDET guys) prevents the coils from arcing to the valve covers. Sold S14 KA24DE 5-speed speed sensor. *picture is generic* speed sensor still in transmission - SOLD VH45DE idle air control valve - Sold 8 "brand new" 370cc injectors in VH45 rails. (about 500 miles on them total) - SOLD S13 cluster, V8 tachometer mod for VH45. plug and play. -Sold 94 VH45 brand new water pump (correct shaft length for 94+ motor). never actually ran on engine. paid $75.00 shipped, asking Sold VH45DE headers with Y pipe / Cats / O2 sensors. SOLD Passenger side Zenki S13 fender trim piece - Sold VH45de oil pan. Sold VH45 / 300ZX TT XTD 250mm flywheel. normal heat marks from being used. Sold Nissan 90-96 300zx Heavy Duty Clutch Fork Upgrade Kit, includes new gasket Z1motorsports cast iron clutch fork, springs, pivot ball and clutch sleeve.Sold Xcessive starter spacer to run a TT flywheel on an NA transmission sold S chassis Aluminum transmission mount. sold Z1 motorsports short shifter and Xcessive relocation bracket with all hardware - SOLD Xcessive alternator relocation plus a remanufactured alternator (ran for about 500 miles) and a brand new goodyear belt. - paid over $300 for this whole setup, SOLD Xcessive VH45 > VG Transmission adapter plate with flywheel spacer / bolts / dust shield -SOLD Full new metal timing setup (all metal guides) along with all necessary bolts that are different thickness than the 90-93 guys have equipped. Paid 250, asking SOLD for everything VH45 MAF in perfect working orderSOLD S13 DOHC > VH45DE SII wiring harness - Sold plug and play. a few broken clips, but it all works 100%. SII VH45DE throttle body - NOT a TCS model - SOLD Xcessive VH45 engine mounts - SOLD Bolt on power steering pump with small pulley. clears the tension rod cross by about an inch. will include a brand new gatorback belt.SOLD
Interested in the trans adapter and the engine mounts… do you have the crossmember and driveshaft to go with the engine mounts?
#24 |
well, its not to discourage anyone, after owning a VH, I can really appreciate stuff that fits, without modifications, which is why i'm putting a KA back in. Sway bars, strut bars, exhausts, manifolds, alternators, etc... everything is readily available, and will fit without mods. but if you can get around working on a VH, once you have all the parts you may need, its a badass engine. when I did have it running, I really enjoyed it. the sound of the DOHC V8 is beautiful
