Old 07-02-2011, 04:27 PM   #1
lg54
lg54 is an unknown quantity at this point
S13: one side wider stance
hello,
on my first alignment with my car, i noticed that the right side (passenger) rim sits further out than the other, it is cleary visible. i have 300zx rear hubs and brakes, everything is assembled correctly, no hits, chassis is straight, and both axle nuts are tight. why does this happen? the alignment was done properly and things where in spec.
i have another thread with coilover ride height and wheel hop. could this affect ride height or cause wheel hop? why is one tire further out than the other?
pics:
Drivers Side
Passenger side (problem)
thanks
lg54 is offline   Reply With Quote
Old 07-02-2011, 04:40 PM   #2
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
something is bent or not in place right. Your car could have been in an accident hitting one side and shifting the subframe location to one side.
Or, Your wheels have different offsets which would be weird indeed. There may be countless differences.
Just read your other thread. Your car is not in pristine condition. Something is fucked. check your LCA in the rear and see if it has a crease. Meaning it's bent.
iamtheyi is offline   Reply With Quote
Old 07-02-2011, 04:45 PM   #3
lg54
I recently changed my entire subframe thinking it was bent or something. it actually made it a bit better, but still the passenger side is further out. while i had the subframe out, i changed my bushings to SPL solids. now i get wheel hop.
Old 07-02-2011, 04:51 PM   #4
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
All s13's are like that.
Flybert is offline   Reply With Quote
Old 07-02-2011, 04:56 PM   #5
hartig
hartig is an unknown quantity at this point
i was just reading this thread and getting nervous, because my passenger's side is slightly further out than my driver's side, but this makes me feel better
hartig is offline   Reply With Quote
Old 07-02-2011, 04:57 PM   #6
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Flybert is correct. Although yours looks a little more exaggerated than normal... maybe its just the angle of the picture.
Old 07-02-2011, 05:03 PM   #7
lg54
ahh that made me feel lot better.
any ways i am still having problems and i would greatly appreciate if you gouys could help me. here are my other threads/problems
#/f/s-chassis/393486...wheel-hop.html
Wheel hop. im having a lot of wheel hop after i installed SPL solid subframe bushings
#/f/s-chassis/394167...ts-higher.html
my coilovers are set at the same height, but passenger side rides higher.
thanks
Old 07-02-2011, 05:12 PM   #8
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Condition if coilovers? One may be out. May explain the wheel hop.
VNG704 is offline   Reply With Quote
Old 07-02-2011, 05:13 PM   #9
lg54
bought them used but in good shape, no leaking or anything. they feel the same stiffness on both sides.
Old 07-03-2011, 11:16 AM   #10
Schwiegz
Schwiegz is an unknown quantity at this point
Sounds like sub frame to me.
same thing happened to me lol, looked ghetto as shit.
But no one cares cause its an s-chassis and 90% of the time we just expect some sorta ghetto riggin.
Schwiegz is offline   Reply With Quote
Old 07-03-2011, 11:54 AM   #11
lg54
nop, not subframe. i recently installed a new one, and i checked it and it wasnt hit or bent.
while i had it out, i put SPL solid bushings.
i guess is not subframe.
Old 07-03-2011, 06:41 PM   #12
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
did you check to see if there was exterior panel replacement or damage. maybe it was replaced and there was human error.
supreme_1 is offline   Reply With Quote
Old 09-06-2011, 01:55 AM   #13
Walperstyle
Walperstyle's Avatar
Same problem, after alignment. My car has solid subframe bushings, suspension arm package (minus RLCA) Everyone says its normal.
3mm spacer part number?
KA-T ORG-Function over Flush
