FS: 1995 KA-T S14 - Factory Manual, SE, Clean title - $5500 firm
![]() Factory SE manual Clean title Selling because I bought at a S13 600 miles on build/tune Mild built ka24de Needs: Oil cooler lines or sandwich plate with oil pressure sensor Brakes bled Coolant overflow reservoir Part List (valued at 6k retail) Eagle rods Wiseco Forged pistons Cometic headgasket ARP studs Gt35 turbo kit 1000cc Injectors Radium fuel rail Oil cooler and filter relocation 400lph fuel pump One piece shaftmasters driveshaft Cusco 2way Lsd diff Enjuku Solid diff bushings Glowshift Boost gauges Glowshift oil pressure gauge Aem wideband gauge Aeromotive fuel pressure regulator Mega squirt pnp ecu Megan racing coilovers Sparco steering wheel Nrg quick release hub Xcessive intake Stage 4 clutch 300ZX front brakes Short throw shifter New trunk, starter and brake booster installed I?m going to part this out if it doesnt sell. No I wont take $5400. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() Join Date: Jan 2019
Nice setup. If you end up parting out I'd be interested in a number of the engine parts namely the intake, fuel rail, injectors, internals and more, if you go that route.
Sent from my SM-G950U using Tapatalk |
I can vouch for this seller. Bought a car from him before and had to travel for it. Everything was as described when I arrived and the transaction was smooth and stress-free.
Free bump and best wishes with sale! |
