| Group Buys Dedicated Forum for Group Buys. |
![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
Godspeed Power Parts Group Buy!
Everything in stock and READY to SHIP AND PICK UP!!! Turbo is the BEST!! Nissan 240SX 89-90 KA24 (S13) Single Cam (KA24E) T3T4 Complete Turbo Kit -T3T4 Turbo Charger .63ar -KA24E Stainless Top Mount Manifold -Aluminum Pre-Bent intercooler Pipe, With Clampes & Silicone -3" Staninless Turbo Uppipe -3"Stainles Turbo Downpipe -Godspeed 38 Wastegate (7PSI) -Oil Feel Line, Oil Return Line With All Fittings -Type RS Blow Off Valve NISSAN 240SX 91-94 KA24 (KA24DE) DUAL CAM MOTOR T3T4 COMPLETE TURBO CHARGER KIT -T3T4 Turbo Charger .63ar -KA24DE Stainless Top Mount Manifold -Aluminum Pre-Bent intercooler Pipe, With Clampes & Silicone -3" Staninless Turbo Uppipe -3"Stainles Turbo Downpipe -Godspeed 38 Wastegate (7PSI) -Oil Feel Line, Oil Return Line With All Fittings -Type RS Blow Off Valve TD04-H T25 TURBO CHARGER Turbo spec. Intake in: 37.8 ex: 59.7 Exhaust in: 45.47 ex: 52.9 Internal Wastegate Set at 8PSI Start Spooling At 2500RPM GODSPEED 38MM GT-SERIES 38MM WASTEGATE (universal) - comes with 7psi waste gate spring ( fully adjustable ) - dual port. accurate boost - ultra durable diagram (diaphram) - comes with all the hardware (bolts, gasket etc) - accurate boost pressure - high quality appearance - 1 year warranty ( if installed by professional) - comes with additional 11 psi, 15 psi springs this wastegate is only 4.35" tall. very compact especially good for customer working with small / tight engine compartment. GODSPEED GT-SERIES 44 MM V BAND DUAL SPRING WASTEGATE (universal) -comes with 15psi waste gate spring ( fully adjustable from 10- 15 psi ) and extra 14psi spring ( if you add both spring that makes it 29 psi total ) -accurate boost pressure , prevent over boosting. -high quality aluminum die-cast body -ultra durable high temperature diaphragm -comes with all the hardware ( v band, clamps and etc) -stainless steel valve -high quality appearance. -1 year warranty ( if installed by professional) GODSPEED GT-SERIES 50 MM V BAND DUAL SPRING WASTEGATE (universal) -comes with 20psi waste gate spring ( fully adjustable from 15-20 psi ) and extra 7.5 psi spring ( if you add both spring that makes it around 27 psi total ) -accurate boost pressure -ultra durable diagram (diaphram) -comes with all the hardware ( v band, clamps and etc) -high quality appearance. -1 year warranty ( if installed by professional) GODSPEED GT-SERIES 60 MM V BAND DUAL SPRING WASTEGATE (universal) -comes with 24psi waste gate spring ( fully adjustable from 15-24 psi ) and extra 7.5 psi spring ( if you add both spring that makes it around 30 psi total ) -accurate boost pressure , prevent over boosting. -high quality aluminum die-cast body -ultra durable high temperature diaphragm -comes with all the hardware ( v band, clamps and etc) -stainless steel valve -high quality appearance. -1 year warranty ( if installed by professional) Nissan S13 SR20DET Intake Manifold Three Style available Cast, Polished, Chromed Cast Polished Chromed S13 S14 240SX Top Mount T3 Turbo Manifold ( sr20det motor ) - T3 Turbo Flange. FIT T3 AND T3T4 HYBRID TURBO - 35MM or 38MM external wastegate flange - SUS321 stainless steel S13 S14 240SX SR20DET T3 Top Mount Cast Turbo Manifold - extremely strong casting - fits sr20det motor (s13, s14 ,s15) - 38mm wastegate flange ( will fit 35mm or 38mm wastegate) - t3 flange. fit all t3 or t3t4 hybrid turbo - life time warranty SR20 TOP MOUNT MANIFOLD + 3" STAINLESS DOWNPIPE + WASTEGATE DUMP TUBE -FITS : TOP MOUNT T3 OR T3T4 TURBO CHARGER -extremely strong stainless steel -equal length for quick throttle response -3" 5 bolt standard flange turbo downpipe -T3 turbo flange -38mm wastegate flange -able to retain A/C power steering -fully TIG welded -Fully ported and polished -includes all gaskets -1 year warranty S13 S14 240SX top mount t3 turbo manifold ( KA24DE motor ) - T3 Turbo Flange - 35MM or 38MM external wastegate flange - SUS321 stainless steel - Fully TIG welded - Fully Ported and Polished - Includes bolts and gaskets KA24DE(dual cam) T3 or T3T4 or T4 Top or Bottom Mount Cast Turbo Manifold - 91-94, 95-98 Nissan 240sx KA24DE (Dual Cam) - 93-01 Nissan Altima - Extremely Strong Casting - 35MM or 38MM External Wastegate Flange - T3 or T4 Flange - life time warranty Nissan 180SX (CA18DET Only) T25 Bottom Mount Turbo Manifold Nissan S13 S14 KA24DE(Duel Cam Only) T25 Bottom Mount Turbo Manifold Nissan S13 S14 SR20DET T25 Bottom Mount Turbo Manifold Nissan S13 S14 SR20DET Turbo Downpipe Nissan S13 89-94 & S14 95-98 SR20DET Catback Exhaust Nissan S13 89-94 SR20DET Carbon Catback Exhaust Nissan S13 & S14 SR20DET Fuel Rail Nissan S13 SR20DET Engine Damper For RB25 Swap!! RB25 Intake Manifold Three Style Available Cast, Polished , Chromed Cast Polished Chromed RB25 Fuel Rail Fit 10.5 to 11 mm feed injectors PM US or CALL US For Better Pricing!!! Let Us Know You are From Zilvia.net for Best Discount!!!! We are S13/S14 Specialist, if you cant find what you need check out our website GodSpeed Project - Intercooler, Turbo Kits, Turbo Manifold, Body Kit or give us a call if you have any question!! We also have other GB on the forum, so please check them out!!! Ken @ Fatboy Garage Motorsport 11135 Rush St Unit B South El Monte CA 91733 626-442-3988 Last edited by Fatboy Garage; 07-20-2009 at 04:11 PM.. |
![]() Join Date: Jul 2007
single slammer turbo kit to 21146
Kouki for sale!! |
who makes the turbo?
Kouki for sale!! |
im looking for a top mount manifold... which do you recomend???? log or tubular?? pm me the price. i need a good STRONG ONE PLEASE LMK ASAP
i fully de-volved
