Rear glass install s13 coupe
Just had the car painted with all windows out:
For the rear window install I am not sure if I need to get just an upper moulding [6] or an upper moulding fastener [7] aswell. I am going to be using my old window if that helps. Anybody able to confirm w this pic below? Thanks! Exploded diagram of parts: AutoCenter.net
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’ Jeremy Clarkson on Automatics |
Nobody has had the rear glass replaced? Sorry for the urgency, just looking to order the mouldings today as they are not in stock and will take 2 weeks to get to Canada land.
just get someone to put it in for you. They can pop it in, in less then 15min and might cost you 40 bucks or you can spend beer money to get a friend over, sealant, and a calk gun, either way same amount of money will be spent just ones less headache.
I am not installing it, I just need to know if I need the upper moulding fastner or not.
#6 | |
![]() Join Date: Mar 2011
As for the moldings, if you have tehm then if they are in good enough shape they will reuse them. If you dont have them you need to let them know ahead of time so they can get the molding kit through their supplier....unless its cheaper for you to get them. Either way the moldings are necessary.
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
