AEM ECU Patch Harness. 1 ONLY! CLEARANCE!
AEM ECU Patch Harness 30-2995 $79.00! (Available on our site in the CLEARANCE SECTION!) This is a great piece if you need to make some connections into your existing harness without having to sacrifice making cuts and splices into your harness. Just tap into this patch harness and leave the existing harness alone! Please note that this harness only works on the following applications: 1991 to 1993 Infiniti G20 2.0L 1991 to 1999 Nissan 180SX 2.0L Turbo 1989 to 1994 Nissan 240SX 2.4L 4 Cyl 1993 to 1994 Nissan Altima 2.4L 4 Cyl 1991 to 1993 Nissan NX1600 1.6L 4 Cyl 1991 to 1993 Nissan NX2000 2.0L 4 Cyl 1991 to 1993 Nissan NX2000 Swapped w/SR20DET 2.0L Turbo 1990 to 1994 Nissan Pulsar GTi-R 2.0L Turbo 1991 to 1993 Nissan S13 2.0L Turbo 1997 to 1998 Nissan S14 2.0L Turbo 1993 to 1998 Nissan S14 EURO 2.0L Turbo 1999 to 2002 Nissan S15 2.0L Turbo 1991 to 1994 Nissan Sentra 1.6L 4 Cyl 1991 to 1994 Nissan Sentra SE-R 2.0L 4 Cyl 1991 to 1994 Nissan Sentra Swapped w/SR20DET 2.0L Turbo
Contact: [email protected]; 407-281-1223 +25 |
