people with s13 digital climate control units
i just installed my s13 dcc, my concern is when i turn the key to the acc or fully turn the car on the dcc lights up bright (the screen).
but when i turn the lights on it dims out if i turn them off its bright again is this normal or is something wrong? its the first s13 dcc i install or even see one install thanks for your help. |
![]() Join Date: Jun 2007
Trader Rating: (25)
its normal. usually when you would turn ur lights on, it'd be dark out. so it's basically dimming it automatically, so it wont be so bright at night time.
-Sellout |
Yes you mount the servo in the 240 and modify it to work. I did it forever ago. Works great but a pita to install
