KA24DE PROBLEMS HELP! Misfiring etc
hey guys, i have a 1992 silvia s13 coupe. the cars currently at 209xxx....Lately the car started misfiring like crazy when i punch the gas on 1st. I cleaned the maf, changed spark plugs, and going to change the fuel filter tommorow. I also got the compression readings checked on it today. The results were shocking and broke my heart lol. Cyl 1=115 cyl 2=115 cyl 3 and 4 =105......What do you guys think, I'm thinking of getting my ka rebuilt....since i don't have enough money for an sr. Let me know! thanks!
Bandwagon.
compression still looks fine, change your sparkplug wires, check different mafs, change out your cap and rotor also if you havent, rebuilding doesnt mean you get rid of the problem.
That comp test done warm or cold?
![]() Join Date: Sep 2012
Compression needs to be at around 170 and the cylinders all have to be within 15psi of each other. Your compression is SUPER low. Your rings are detroyed. You notice alot of burning oil, dont you?
Wiesco pistons .02 over Eagle rods ARP mains and studs Felpro Head Gasket OEM Timing set ![]()
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane |
i have the same problem with mine and i bought it like 2-3 months ago from onemotion its a shop in philly cool ppls but i paid way tomuch and didnt tell me the oil pan had a whole in it but it was a pin whole so i have to add oil like every 2days and the mother smokes like shit since i put it in i just wanna swap it honestly
| 240sx, ka24de, misfire, problems, rebuild |
