![]() Join Date: Feb 2002
Enjuku Racing - ISIS Pro 5 Lug Conversion Kits ** ON SALE **
ISIS Performance PRO Series 5 Lug Hub Conversion - Nissan 240sx 89-94 S13
![]() ![]() ![]() ISIS Performance PRO Series 5 Lug Hub Conversion - Nissan 240sx 89-94 S13 - Enjuku Racing Parts, LLC Product Description ISIS Performance PRO Series 5 Lug Hub Conversion - Nissan 240sx 89-94 S13 These 5-Lug hubs are a direct replacement for your 89-94 Nissan 240sx. This is a full set - front and rear. Unlike other 5-lug conversions, this does not need any modifications to the spindles or balljoints. Simply remove your stock hubs and replace them with these. Specs are as follows: 5x114.3 Front Hub: * Extended Wheel Studs - On Pro Series * Thicker Flanges - On Pro Series * Upgraded Front Bearing - On Pro Series * bearing & lightweight designed * Compatible with all kinds slotted rotors & spacers * Requires removal of brake dust shield Rear Hub: * Extended Wheel Studs - On Pro Series * Thicker Flanges - On Pro Series * CNC Machined for precision and accuracy * Requires Pressing in factory rear bearing assembly or purchase of new rear factory bearings
![]() Join Date: Jan 2008
"Simply remove your stock hubs and replace them with these"
"Requires Pressing in factory rear bearing assembly or purchase of new rear factory bearings" Which one is it? |
The front hubs should be a direct bolt on replacement.
The rears requires pressing as mentioned in the description. This could have been listed more clearly. Sorry for the confusion. I will bring this to the attention of the manufacturer and have this updated.
