#182 |
parts shop max s13 sr20 high mount inner cooler works with t28 bottom mount and s14 sr20 inlet WITH RB26 PINK MAFF with some finagling the only thing im not sure on is not running a bov im testing it as wee speak seems to be OK but has a lot of compressor surge and instant response! ill let you no how it changes my tune next time im on the dyno
#183 |
Okay so this might seem like a noob question, but i do need some help guys..
I just got an automatic 240 s13 hatch and it had a KA in it.. I just recently bought a CA and it came with a harness and I changed the car into a manual.. I left the cars harness in.. I need help with the wiring if anyone can help me? please! If this makes any sense.. ![]() Thank you |
#184 | |
#185 |
Hello all. I have recently been buttoning up the last few things on my ca build into my s13 coupe. Just a few pointers that I didnt see were posted in this thread. I have just replaced the head gasket and had a rough time getting my header back on because Im running an s15 bb turbo. The reason being was because im running the stock ka motor mounts and the turbo is super close to the mount. I dont see it affecting anything but I do plan on getting different mounts. If anyone has suggestions on which mounts i should get that would be great!
#186 |
![]() Join Date: Nov 2011
Has anyone made any time of bracket to use a ka a/c compressor? single or dual cam.
Also, has anyone ran a water to air set up on their CA? I live in Texas and its getting into the triple digits already and a fmic would be pointless for my daily as it would block my radiator and A/C condensor. I know this thread is old but I don't want to create a new one and everyone tell me to search, because I have already. |
#188 |
I forgot to mention, i have tubbed wheel wells. I was going to go with a high mount from pbm but i would not be able to mount my ac condensor. So back to the question on water to air. Anyone?
#189 |
Hello,
Im going for MegaSquirt, for s13 CA18DET, but i need basic ignition and fuel maps, to get started can anyone post screenshot from VEMS,KMS,NIStune or maybe Megasquirt? I need only screenshot with values of ignition and fuel maps ![]() |
#190 |
I have been looking at a car with an auto CA18det how hard would it be to swap to a manual transmisson? if anyone has a thread or link that could help so i can further research this before i buy the car.
thanks, |
#191 |
![]() Join Date: Aug 2011
you need a flywheel, clutch, clutch line, clutch pedal, and maybe a remap (i know auto ECUs has special circuitry for kickdown and it may run degraded mode when it does not detect it.
My advice, either stick with the autobox (which is quite good actually) or get a manual S13. It will be cheaper than swapping a manual and hassle free. |
#192 | |
Thanks for the info! |
#193 |
So glad that there is still a ca18det forum section!
New to 240sx and ca18dets, what would you guys say are almost *necessary* pre-install maintenance I should do. I bought the engine as a *running* engine, just want this to be a pretty reliable DD, boost will be kept at 10psi on stock turbo. Also if anyone has a ca18det power steering pump hit me up ASAP. I have cash in hand. |
#194 |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
Question about running a SRt25g (s13 T25) on the CA18det...
For oil return lines, will I need a SR or CA return line? I've searched and searched but cant seem to find the answer. ALthought the turbo placement is simliar, I'd like to have everything installed first. I have already clocked the compressor housing and tapped the outlet pipe for the wastegate source.
#196 |
This is urgent!!!!
I am driving across canada back to Ottawa and my Silvia has gone kaputs on me. my battery blew and melted my fusebox and my alternator is toast as well. Can I use any fusebox from other schassis? I assume I can only rebuild me ca alternator. Any answers and help would be appreciatted. I am currently stranded in Calgary while i try and source parts. Luckly i have friends in town who took me in. Cheers |
#198 |
Hey everyone! I am new to the forum and have searched high and low for some answers on the possible issues with using a lightweight crankshaft pulley on my ca18det. I have seen mixed reviews on the subject of putting the lightweight pulley on. Some say it is bad since the stock is harmonic. I havent read anything saying that once it was own the person had issues but a lot of people have advised against it. If anyone has a solid answer let me know. I greatly appreciate it.
#199 | |
Don't!
My +700hp RS13 |
#203 |
My +700hp RS13 |
#204 | |
I believe 2 companies make a good crank pulley, with harmonic balancer and all. Cant remember the name on top of my head though, 1 is australian. This is going to cost quite some money anyway so i suggest you dont get one, unless your stock pulley is broken. |
#205 | |
![]() Join Date: May 2010
Trader Rating: (26)
#206 |
Yeah my pockets aren't that deep haha. I may call raw brokerage and see if they have an oem one laying around. I think I may have found one. I could go through Nissan motor sports and get my dealer discount but they only stock Sr and rb parts. Can't wait 8 weeks for one from Japan. My stock one is bent so it's no good.
#209 |
Found one!! JDM Parts and Racing Accessories direct from Japan: RHDJapan.com has one and a bunch of other stuff. I appreciate the help. Can't wait to get the motor back from the machine shop and put it all back together.
#210 |
![]() Join Date: Mar 2012
KA24DE clutch and pressure plate work you just have to drill out a hole for the dowel pin and use a 7/16 drill bit to enlarge the mount holes along the outside and it will work fine.
