Well you see I already have the turbo laying around and temporarily using this frees up extra funds to finish off everything else. I'll be going with a Peak boost top mount mani so just wanted to make sure that there wouldn't be any fitment issues.
![]() Join Date: Apr 2008
i would only use the Rb25 turbo as a bolt on upgrade with the stock manifold . ( only for skyline )
if you are going to upgrade your SR with a top mount manifold , forget about a stock Rb25 turbo . what i would do is take the turbo to your nearest turbo rebuilders and get them to make a t3/t4 for you. works well on SR , i've seen it been done |
#8 | |
![]() Join Date: May 2003
Plus it has the weird 6-bolt flange on the turbine exit. More trouble than it's worth. |
Hmm I will be getting steel braided turbo lines. I got the turbo in my possession and things are tight money wise and want to be able to at least drive my car until I get some spare cash for a gt2876r.
The only part that has me stuck is how I would go about doing the elbow coming off of the turbine side. Would it be easier just to temp. run a bottom mount manifold for the time being till i save up more cash in a few months time. I'd be able to get one for fairly cheap off of someone I know. THoughts? Last edited by CoreyS13; 02-27-2009 at 03:37 PM.. |
Bump.
After some thought If I am running braided steel lines for the oil/coolant and an external waste gate then the only part that will be fun is routing it out the exhaust side? I just want to run this turbo seeing as i already have it in my possession and money is tight right now seeing as I am putting together a huge build withing a few months. I will be running a GT2871r .64 after. |
