![]() Join Date: Sep 2006
Trader Rating: (313)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 313 reviews
T3 turbo, N62 MAF, 370cc injectors, SR ignitor
Turbo-$SOLD
Bought this a while ago for a budget KA-T setup but I figure a T2 setup would be easier for me. It is from a Ford Thunderbird Turbo Coupe. Turbo has some side to side shaft play and will probably need a rebuild. Rebuild kits are cheap on Ebay. It will need new gaskets for the intake pipe and oil drain(needs a mounting bolt too). Here are some specs I found on the turbo: * Garrett model number: TB0322 (T3 series turbo) * Compressor Trim: 60 * Compressor housing A/R: .60 * Turbine housing A/R: .63 * Horsepower Capabilities: ~325hp * Internal Wastegate: Yes * Wastegate setting: 7 psi The wastegate flap thing is built into the outlet which I do not have so an external setup would be needed and I'm guessing that's what most people would use anyway. MAF-$SOLD It is in good working condition. Has about 7in of wiring. 370cc injectors-$SOLD They're in good working condition. They will drop right in to a KA fuel rail. Ignitor-$SOLD Works fine. Pigtails included. Last edited by MrMcgarrett; 09-20-2009 at 07:32 PM.. |
