Old 12-31-2012, 10:09 AM   #1
nismo_drifter
nismo_drifter is on the path to ruinnismo_drifter is on the path to ruin
anyone try these before?
am i missing something here? is the price correct? how does it perform?
Megan V2 Adjustable Front Swaybar Sway Bar Stabilizer 240sx s14 Silvia 28mm | eBay
nismo_drifter is offline   Reply With Quote
Old 12-31-2012, 10:21 AM   #2
Sileighty_85
Sileighty_85's Avatar
Garbage is usually pretty cheap
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-31-2012, 10:28 AM   #3
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Based on specs provided and not based on actual experience, this bar is a bit thicker than stock fronts. ABS/SE models had 25mm, while base models had 24mm. This Megan sway bar is 28mm and I'm not 100% but I think Megan bars are solid as opposed to OEM's hollow construction.
There will be added stiffness and adjustability when using these bars when compared to stock. Depending on how you intend to use the car, these will be a slight upgrade from stock.
However, if you're going to upgrade sway bars, I would definitely go with Sikky, Nismo, Cusco, Whiteline OR Progress sway bars. I believe Sikky, SPL Cusco, Whiteline, and Progress sway bars are all adjustable. SPL provides heim joints which can be beneficial if this car is used for the track only. Nismo is 30mm. I would never purchase Megan parts due to their hit and miss nature.
I wouldn't call them garbage but I think for the money or with the intent of saving more (for better), you can purchase something better.
Old 01-01-2013, 11:38 AM   #4
Croustibat
Croustibat is an unknown quantity at this point
It is a bar. And it is not that cheap. Did you just reply because you saw "megan" in the title ?
It just is a copy of the whiteline bars, same diameters, same adjustability front and rear.
Contemplating getting one but for that kind of money i'd get a progress bar.
Edit: there is a typo on that ad, you dont get it for that price. I saw that one too. Check the other bars from the store and you will see.
Croustibat is offline   Reply With Quote
