![]() Join Date: May 2008
tips on how to fix my garage
um ok this sucks my car is stuck in my garage now. my damn door broke like its slanted now one of the wires is hanging down and i dont know what to do.
aWingThing.com
![]() Join Date: Mar 2003
I'm moving this to tech section. I don't see how this is Off Topic.
You might want to be a little more descriptive with what the actual problem is. I don't understand what the hell you are trying to say.
![]() Join Date: Oct 2005
the cable is attached to a pulley on one end of the garage door. It broke therefore the other end is still trying to pull the door up, that is why it is slanted. There is a large coiled up spring above the garage door that assists in raising up the garage door. If you disconnect the garage door opener via the red handle you should be able to lift the garage door and prop it up with something. Keep in mind that it is going to be very heavy, especially if it is a 2 car door. Have someone come over to replace the cable that snapped and whatever you do:
DO NOT TRY TO FIX IT YOURSELF!!!!!!!!!!!!!!!!!!! The spring at the top has a tremendous amount of tension on it and if not dealt with properly it will break fingers, hit you, overall ruin your day. |
hey guys sorry if i got crappy typing skills ok heres my problems. alright well fist of all i was sweeping my garage and when i was finished i left a broom on the rail by accident because i forgot to move it well then i closed the garage and the garage went reverse but in a slanted way so i tried opening it again and it just got stuck slanted so the cable got loose and slid off the end tabs are still on there just gotta put it back on and tighten up the tension springs like i did last time with my friends. and i still havnt fixed it yet my friends coming over to do this for me he put together his garage at his fathers house so hes pritty top notch with working on garage doors
![]() Join Date: Jul 2005
bro fix that yourself... i did when that happened to mines... that metal piece on the wire clips on the thing that the wire is wound up on.... i did this myself just last month bro... dont pay to get it fix they will buck the living out of you... its not hard... i think the easiest way to fix it is when the garage is in the up position... thats how i did mines... simple as abc
![]() Join Date: Feb 2006
My brother almost got his finger taken off when we tried to fix our door. 9 stitches in his finger.
If you really need your car put it in reverse and give it as much gas as you have in the tank... |
oman your fucked, throw it out and start over.
but really garage doors are not to be taken lightly they are dangerous.
I was going to, but I can not think of a sig less than 75 characters. |
#18 | |
No Limit Soldier.
![]() Join Date: Jan 2006
I'll fix it. and drop off some parts you might need ![]()
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only" |
#20 |
No Limit Soldier.
(510)712-9688
Same one player.
#24 |
![]() Join Date: Mar 2006
yea man watch out the garage door repairmen will rape your butt. when they came out to fix our old garage before we moved out, the bill was hundreds, and all he did was mount up a new spring basically
Goodnight |
#25 |
![]() Join Date: Jun 2003
Yea, doors with that central spring can be a bitch, you have to put a shit ton of tension on them.
If you don't know what you are doing, I wouldn't fuck with it, you can seriously fuck yourself up.
Team Pterodactyl SHARK ATTACK!!! LookoutDrift |
#26 |
yeah the guy is coming at 3 im hiding all my tools and stuff just in case. nothing is broken i just need him to line up the garage and put the cable on and if he charges me for parts im not paying him jackshit.
#27 |
its really easy..
you just connect the lines on the bottom, let the door down all the way. start tensioning up the middle section with 2 bar stocks. longer the easier. it's not that hard.. i did it 10+ times when my dumbass dad kept trying to close the door (electric opener) and it finally unravelled from the drum and fucked it up. its not harddd
My iTrader rating! |
#29 |
wassup ant hit me ill help you... simple ass shit to fix... yurn it down you know the deal hahaha.. it really isn't hard... i know my cable is still a little loose on one side cause i wound it on the thing wrong but its still works... does up n down.... FUCK callin R & S erection they charge up the ass
