Help wiring top feed injectors!
As title says I want to wire in these topfeeds. Only problem is the clips wires are both black.. Whereas the others are red and white. Red and yellow. Red and... etc. I know the red will either go all on right or left but which one.. or does it not matter which way I wire as long as all reds are on same side?uploadfromtaptalk1411084526796.jpguploadfromtaptalk1411084537886.jpguploadfromtaptalk1411084545496.jpg
When I searched about this topic, I found out it didn't matter. I simply made it so all of the original wires connected in the same manner. I laid it out and wired it in so all of the red wires were on the right and the other colored wires were on the left. I haven't fired up my car yet, so I am not 100% sure it worked or not. Hopefully this helps.
Sr22 in the works |
