| Mid-Atlantic States DC, Delaware, Kentucky, Maryland, New Jersey, New York, Ohio, Pennsylvania, Virginia, and West Virginia. |
s14 with s14 sr20 wont stay running, and gauges dont work....helppp
ok, I have and 1997 s14 with a zenki sr20det with 480cc injector z 32 maf with stock ecu and a untuned safc 2. The car only starts if i put it on a slow charge for at least 2 days. when it starts it will idle for a few seconds then die out i can keep it running if i keep revving it up high soon as i let off of it it dies. I've tested the alternator its fine I have also checked the cas took it out and spun it injectors click fine. None of the gauges work but all the lights come on as normal, the safc 2 is reading volts and throttle position but it is not getting a tach signal. I also have the conversion harness from wiring specialities, and new fuel pump.
Need help to know where to go from here anything i can check, how to know if you have a bad ecu or could it be a bad sensor, or could the timing cause this ?? |
![]() Join Date: Apr 2008
Trader Rating: (18)
How does it run with stock 370cc injectors and stock maf?
You really shouldn't be screwing with that stuff unless you are an experienced tuner. Get a new battery and take it to a shop. |
what do you mean dont mess with stuff unless your an experienced tuner?? haha I was gonna take it to get it tuned after I put it together cause it didnt come with a maf and the injectos got fucked up so i put 480cc in it so i dont have stock replacments, its been in and out of the shop and a grand poorer trying to find this problem and it does have a new battery, the shop told me its the ecu but i wanted to see if any would could help cause i really didnt agree with it cause it will run some times , not to tell me to take it to a shop ha
| gauges, s14, sr20det, wont stay running |
