#31 |
![]() Join Date: Dec 2004
Trader Rating: (58)
PM 'Steve Shadows'
#33 |
![]() Join Date: Jul 2006
![]() ![]() Feedback Score: 29 reviews
put up a video so people can hear it, dont run it first pull out your oil pan check your oil pick up make sure is good and look for brass shavings, also make sure your oil pan isn't dented
#34 |
I had already installed a s14 pick up and new pan before starting it. When I removed the previous pan it had no metal shavings and the oil was clean. The previous pan had some light dents but nothing major.
I'll try to put up a video. |
#37 |
![]() Join Date: Feb 2008
![]() ![]() ![]() Feedback Score: 6 reviews
i know it sounds kinda stupid but look at ur alternator bracket.. cause i thought i had some upper valve noise and turns out to the the altornator bracket was broken it did it at the same rpm range..
#38 | |
![]() Join Date: Aug 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
![]() X2 Mine turned out to be my Alternator pulley bearing was getting ready to seize so it would knock (Knock would come and go might I add) and sounded like noise was coming from the engine, till one day it finally just seized in front of my driveway while it was running I immediately turned car off. Here's a clip I took of the knocking
![]() FS OEM RB25 PARTS |
#40 |
I recently had a rod knock SR...For about 1K in parts you can build a pretty nice bottom end and not have to worry about it again. Eagle rods, Supertech pistons and rings, ACL bearings, new OEM oil pump and pickup, etc.
Thats basically the route I went with mine. Hopefully your crank is fine. But yeah..gotta pay machine shop charges too... Idk, fuck its late. Sorry about your motor. |
#41 | |
yeah i am kinda tight on cash and im trying to see what route to go with thanks for the help damm im still pretty bummed about my motor and its been almost a month..
