![]() Join Date: Dec 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
![]() Autotech Motoring VVL SR20 Solenoid Relocation Adapters V2.0 - Nissan SR20 VVL Hybrid Engines $199.99 msrp - CALL US FOR ZILVIA PRICING This new kit features 2 separate relocation adapters similar to the older design but with some differences. The relocation block that goes on the head now uses a single solenoid application for a much simpler install without having excessive lines. The 2nd adapter you see will be "sandwiched" in between your factory oil block adapter to provide the oil feed to your solenoid relocation block. It will include a line that goes from the oil block to the solenoid relocation block. Notes: All hardware and line will be included. Clears RWD conversions engine firewall ![]() Autotech Motoring VVL SR20 Conversion Water Necks - Nissan SR20 VVL Hybrid Engines $139.99 msrp - CALL US FOR ZILVIA PRICING When converting over to a VVL cylinder head on a RWD SR20 application, it is necessary to change out this water neck located on the back of the cylinder head. Made from billet aluminum 6061-T6 and anodized black ensures that this will be one of the best units you will find for your conversion. Notes: Includes hoses and fittings ![]() Autotech Motoring VVL Intake Manifold Billet Aluminum SR20VE $699.99 msrp - CALL US FOR ZILVIA PRICING The full billet intake upper plenum bolts to a stock SR20VE lower. The kit will include the billet upper plenum, plenum adapter plate that goes to to the stock runners, IACV adapter plate, and bolt on throttle cable bracket. This Kit will also include the billet upper plenum, plenum adapter plate that goes to to the stock runners, IACV adapter plate, and bolt on throttle cable bracket. Notes: Limited quantities available. Click Here to start shopping now! Thanks, FRSport Team Tel: 714-515-4001 Toll-free: (800) 321-GRIP (4747) AIM: FRSportsales Email: [email protected] WWW.FRSPORT.COM | 18050 Newhope St. | Fountain Valley, CA 92708
FRSport.com || 18050 Newhope Street, Fountain Valley, CA 92708 (Map link) Store Hours: Mon - Fri: 8:00 AM - 6:00 PM PST [email protected] | 800-321-4747 | 714-515-4001 ext 146 FRSport.com Open Box Clearance Items FRSport.com Weekly Specials |
No you do not specifically need the P12 solenoid. If you have the P11 solenoids, any one of the 2 solenoids will work.
| billet, solenoid, sr20, vvl |
