![]() Join Date: Jul 2003
Trader Rating: (357)
Genuine CUSCO Rear Upper Camber Arms
Fits Nissan Silvia / 240SX S13 1989-1994 S14 1995-1998 Nissan 300ZX Z32 1990-1996 Nissan Silvia S15 1999-2002 Nissan Skyline R33 2WD & GT-R 1993-1998 Nissan Skyline R34 2WD & GT-R 1999-2002 Nissan Stagea WC34 2WD & 4WD 1996-2001 While these where originally designed for the S14, they retroactively fit the S13 and Z32 as well. I have test fit them to confirm. Provides +10 degrees to -6 degrees of adjustment IN ADDITION to the range of the stock camber bolt. Arm bodies were media blasted and powder coated blue by a local shop that specializes in airplane grade finishes Hardware was fully disassembled, and silicone water / weather resistant greased All threads spin free and fully adjust Heim joints do not bind and are butter smooth As pictured all spacers are included These are the thickest, beefiest arms on the market, they have thicker metal and larger heim joints than any arms I have compared to! Super strong construction, top grade heim joints, built to last - don't trust your car to no-name junk. List price is well over $400.00 Product Details Cusco Rear Upper Arms provide proper camber angle and improves car movement. Prevents irregular tire wear and keeps the tire planted to the road surface. You'll also have more precise wheel alignment with the addition of the Cusco adjustable rear toe control rods. The turnbuckle will correct the improper camber that is caused by the change of vehicle height PRICE DROP SOLD ![]() ![]() ![]() Last edited by Bernie (NoVA); 05-01-2020 at 08:39 AM.. |
