I have a 60mm throttle body that came off a s14 non turbo engine. This will fit both S14 and S15!!! Stock turbo s14/s15 throttle bodies are 50mm so this is a significant upgrade. This should give you at least a 5-10 hp increase and maybe more in the higher rpm range. This is especially important on big turbo/higher hp cars where that 50mm TB will choke it a little.
The throttle body is in great condition. Comes with the A/T TPS but will still work with any SR harness. If you have a manual trans harness, just plug in the TPS plug to the top plug on the TPS sensor. If you need the bolts for the TB just let me know and I will include them.
Price: 110 shipped These TB are somewhat rare and hard to find so get it while you can.
PM me or email at
[email protected]
COMPARISON b/w n/a and turbo TB:
