![]() Join Date: Apr 2009
Reposting an updated list with prices, this is everything I have left:
I just pulled the KA 3 weeks ago and swapped in the SR & all the parts, so everything is in good working condition. Everything is priced with Shipping (let me know if you live outside the 48). I have pictures of most everything, PM me if you don't see something though. I will ship within 1-2 days of receiving payment. Thanks! Zenki SR20DET S14 Parts: -OEM SR20 Clutch Slave Cylinder w/ Rubber Hose intact - $25 shipped -OEM SR20 Clutch & Flywheel: $55 shipped for both (may need resurfacing) -SR20 Turbo Elbow: $25 Shipped -SR20 Hot Pipe: $25 Shipped -SR20 OEM Water Pump in good condition: $20 Shipped -SR20 OEM Thermostat (used): $5 Shipped -SR20 Stock Shifter: $25 Shipped (does not include rubber piece) 1996 Zenki 240sx KA24DE Parts -OEM Air Box Setup with K&N Drop In Filter in good condition: $35 shipped for everything -Radiator (no leaks, good condition) -$40 Shipped -Fan Shroud (still has lower insert)- $35 Shipped -Electric Fan (wires have been cut)- $25 Shipped -KA24DE Clutch Fan Assembly - $35 Shipped -OBDII Crankshaft Position Sensor (mounts on bell housing) - $20 Shipped -Cruise Control System (everything including Solenoid, Cable, and Actuator): $30 Shipped -Clutch Damper Line: $15 Shipped -Base OEM Headlight Stalk/Switch $20 Shipped -SE Model Headlight Stalk/Switch for Fog Lights - $30 Shipped -240sx Zenki Style S14 Fog-Light Blanks for Front Bumper - $15 shipped -OEM S14 Zenki 240sx Bumper Reinforcement Bar - $60 - PM me for quote -Good Condition Pre-Cat (Exhaust Section that connects exhaust section to main cat) w/ lower O2 sensor attached - $45 Shipped -OEM Nissan Alternator - $40 Shipped 1990 Nissan 300zx Twin Turbo Parts: -300zx OEM Ignition Coil Packs (I have 3) $15 each Shipped -300zx OEM Eprom Chip - $35 Shipped -Knock-off Jim Wolf Stage 3 Eprom ECU Chip (90 300zx Manual Trans, Federal Emissions) - $75 -Bumper Reinforcement Bar & both bumper shock absorbers - $50 (PM me for quote) Universal Parts: -Sard Pro Meter EL Boost Gauge (white faced with indiglo backlighting) 60mm, 2.5 bar, with original (Japanese) instruction manual, Silicone vacuum line, and the full length uncut electrical harness. SARD gauges are highly accurate, and this lightly used unit is in perfect working condition without any scratches or blemishes. - $85 shipped This800x600 image has been resized. Click this bar to view the full image. The original image is sized . Last edited by K8ee; 07-07-2009 at 11:41 AM.. Reason: Updating Items |
Sounds good! My paypal is [email protected] Thanks!
