Everything is less than $20 dollar sale!
Backstory: Bought a non running 92 S13 hatch parts car to use as a donor for a 5 speed swap. Parting out the rest. Everything is obo, but come on, I'm pricing parts to move, not to clear a nice pay day. Car obviously started out a DOHC. My forensic expertise tells me that it was a SR/KA-T that blew, so someone decided to attempt a SOHC swap, but didn't have the time/knowledge to complete it, so it sat. Interior trim is tan and grey. Don't know much more about it than that. I'll do my best to answer any questions. I will mark parts sold as they are sold. Anything that can fit in a USPS flat-rate box will be shipped. Anything bigger than that is local pickup only.
Note: PRICES ARE CHEAP AF BECAUSE IT WAS A MISSILE AND I'VE TESTED NOTHING! Messages asking about if something works or not will be ignored. Prices do no include shipping. 5 speed swap related parts aren't for sale and I make no guarantees on parts. I've never seen it run and it's not worth my time to test these pieces. 1. HVAC tubes - $5 2. Defroster tubes - $5 3. More HVAC tubes - $5 4. HVAC tube that goes above steering column - $5 5. SOLD - Headlight/turn signal stalk (faded) - $5 6. SOLD - Wiper stalk (faded) - $5 7. No clue, but it came from the passenger side kick panel - $5 8. No clue, came from rear driver's side engine bay - $5 9. AC evap unit - $10 10. Blower motor - $10 11. Heater core - $10 12. Throttle cable, gas pedal - $10 (no clue if its a SOHC or DOHC cable, will answer any questions to narrow it down.) 13. Wiper motor (spray painted fukboi pink by someone) - $10 14. Wipers (with fukboi blue spraypaint) - $10 15. No name aftermarket radiator hose T fitting for turbo coolant line - $5 16. Passenger B-pillar exterior hatch trim - $5 17. SOLD - Brake master cylinder - $10 18. Brake hardlines - $10 19. Brake booster, Non-ABS - $10 20 & 21. KA harness. Some redneck hacked it up. Also tried to wire in VG injector pigtails. Point out any specific pigtails or relays you want and I'll clip them off. - $5 per pigtail or $20 for the whole harness 22. Dash bar - $10 23. Dash (cracked) - $20 24. SOLD - Driver's door, power mirror, glass, interior door panel (exterior handle is splitting in the middle) - $20 25. SOLD - Hood (underside is separating from bracing. Mad floppy) - $20 26. Hood prop - $5 27. SOLD - Driver side complete headlight unit with motor (no guarantees on motor) - $20 28. SOLD - Passenger side complete headlight unit with motor (no guarantees on motor) - $20 29. KA24E distributor, plug wires, igniter - $10 30. Dome light, no plastic cover - $5 31. SOLD - Koyo radiator - $20 32. SOLD - Chuki bumper (metal on lip is bent) - $20 33. SOLD - SOHC "complete" engine. - $20 + $20 + $10 (see, still $20 or under). I have no clue of its condition. Looks sloppily assembled. It has been pulled since the picture. Will tear down further and part out if requested. 34. SOLD - Aftermarket motor mounts, no name, no clue. - $20 for pair 35. Steering column, rack and pinion assembly (will pull at request) - $20 36. Passenger door, power mirror, window glass, interior panel - $20 37. Passenger rear armrest trim - $10 38. Passenger C-pillar trim - $10 39. Passenger strut tower trim - $5 40. Driver A-pillar trim - $10 41. Passenger A-pillar trim - $10 42. Driver upper rear trim - $5 43. Driver rear armrest trim - $10 44. Driver automatic seatbelt assembly with motor - $10 45. Passenger automatic seatbelt assembly with motor - $10 46. SOLD - Passenger seat (mad rough) - $5 47. SOLD - Center console - $10 48. Strut tower speaker grill - $5 49. SOLD - DOHC gauge cluster, ~173,000 miles - $20 50. Gauge bezel with headlight up/down switch, hazard switch - $10 51. Random intake piping - $5 52. Ignition with key, very worn down, still engages though - $10 53. No idea, it was plugged into the harness - $5 54. Dizzy plug wire cover - $5 55. Center vents - $5 56. Intake piping - $5 57. Intake piping, not sure what from. - $5 58. Lower dash trim around steering column - $10 59. Strut tower speaker grill - $5 60. SOLD - Driver front quarter panel - $20 61. SOLD - Passenger front quarter panel - $20 62. SOLD - Hood latch and cable - $10 63. Rear seat bottom - $20 64. SOLD - No name SOHC headers - $20 65. Rear seat back - $20 66. SOLD - Tail lights - $20 67. SOLD - Driver seat, mad rough - $5 68. Seat belt - $5 69. Seat belt anchor - $5 70. Kick panel fuse box cover - $5 71. Climate control unit - $20 72. Another seat belt - $5 73. Another seat belt - $5 74. Seat belt anchor - $5 75. #15 ECU - $20 76. SOLD - Chuki front turn signals - $20 77. Seat belt - $5 78. Seat belt - $5 79. No clue, bracket that came out of the engine bay that was spray painted fuckboi pink - $5 80. Wheel well plastic - $5 81. Interior door handle trim (will include with complete door if sold) - $5 82. Interior door handle trim (will include with complete door if sold) - $5 83. Blank gauge bezel buttons - $5 84. Seat belt anchor - $5 85. Rear passenger ash tray - $5 86. Random dome light found in floorboard - $5 87. Oh shit handle - $5 88. Antenna connection - $5 89. Random coin tray - $5 90. Random plastic trim - $5 91. No idea wire harness. If you can identify it and want pigtails off it, let me know. - $5 per pigtail or $20 for whole harness (Edit: I don't know why embedded images aren't working. See the Imgur album link below until embedded images fixed) http://imgur.com/a/8iTGA
WTB: boot cover bag, vert roof header garnish, vert roof header cap Last edited by partytron69000; 02-29-2016 at 05:41 AM.. |
#5 | ||
WTB: boot cover bag, vert roof header garnish, vert roof header cap |
#9 | |
Sent from my SM-N920V using Tapatalk
It would be cheaper for you to drive down to Nashville than it would be for me to ship them. Just a thought.
#16 | |
Sure, PM me the zip code.
#19 |
It's in fair condition. Don't think it'll fit in a flat rate box though.
Thanks boss. Just get this shit out of my garage. That's all I want.
#20 |
![]() Join Date: Jan 2008
Trader Rating: (26)
I want #58 and do you have rear trunk area interior pieces, the carpeted ones around the strut tower and behind the tailights. Would you ship? Thanks
ಠ_ಠ |
#22 |
Please see the note about flat rate shipping in my original post. I do not have any more trim pieces other than what's listed. Sorry boss.
WTB: boot cover bag, vert roof header garnish, vert roof header cap Last edited by partytron69000; 02-17-2016 at 08:07 AM.. |
#25 |
Bump. More parts sold. Keep 'em coming. Clean me out, make me an offer. Of trade me for some random 5 speed parts or vert trim i'm looking for.
#27 |
dawg, take 2 minutes to read the parts list and you'll find your answer.
#30 |
Email sent to the scrapper. Make me a deal before the junk yard gets it.
