Brembo brakes on s13 question !
hay i am new to this form and i need some help. yes i have searched and cant fined my answer. i bought brand new Brembo calipers, rotors and pads from a Nissan sentra se-r for my 1991 240sx as i have searched and found out they bold on to my 240sx.(i haven't installed them yet) the rotors are 4x114.3 just as i needed before but now i decided to go 5 lug so 5x114.3 so i looked around and not many places in my area drill rotors and places that do cost too much. my question is what other rotors can i use that are 5x114.3, fit 240sx, and will work with my brembos ? i was told 300zx non-turbo but i cant find more info to prove it. thanks
![]() Join Date: Jun 2007
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
get a drill. Not a cheap one for $5, but something around $40-$60 should do. Clamp the rotor that has the correct lug patter onto the new rotor and drill the pattern out. It works and remember you can't really mess up the rotor, cuz it's held in the center by the hub flange and not the wheel studs.
![]() Join Date: Jul 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
hub centric, so drill as much as u want as they said
but I don't think the rotor's hat offset will be the same, only one way to find out. remember that rotor has to lineup directly in the middle of that caliper or it would work correctly.
| 240sx, brakes, brembo, conversion, rotors |
