![]() Join Date: Aug 2009
![]() Feedback Score: 27 reviews
ALL PURCHASES COME WITH INSURANCE, TRACKING INFORMATION, AND LEGITIMATE PACKAGING.
Some sellers are so terrible that is actually makes a difference to say that... Shitty isn't it? Text me for questions, info, or ask if I have something you need. TEXT ME PLEASE - 361-571-1026 DEAN NEW PARTS TO THE LIST: S13 Climate Control (Mint Condition) - $40 shipped ![]() S13 Rear Side Marker Lights - $20 shipped ea $30 shipped for both ![]() S13 Fuse Box Pigtails - $10 each shipped ![]() S13 OEM E-Brake Cables (GOOD Condition, not stretched) - $60 shipped S13 KA24DE Engine Harness Pigtails - PM me what you need $15 shipped each -S13 License plate light assembly - $25 shipped -S13 Window Amp - $25 shipped -S13 Ash Tray - $25 shipped -S13 Passenger Side Power Window Trim with switch - $25 shipped -KA24DE Oil Cap - $20 shpped -Driveshaft carrier bearing top half - $15 shipped -S13 Hatchback Trunk Light - $15 shipped -KA24DE Fuel Injector Caps - $15 shipped for 4 -S13 Door Handle Trim - $15 shipped -240sx Gas Cap - $15 shipped S13 Fuel Pump Harness Metal Cover - $15 shipped S13 Pop-Up Headlight Motor Covers - $10 shipped per pair S13 Gas Pedal Assembly - $20 shipped KA24DE/E Oil Filter Block - $20 shipped 240sx steering shaft U-Joint w/ bolts - $25 shipped 240sx Power Steering Rack Brackets w/ bolts - $25 shipped KA24DE Fuel Injector Bushings - $8 shipped for 4 KA24DE Cam Sprocket Bolts w/ washers - $10 shipped per pair 240sx Shock absorber cap - $5 shipped 240sx Hub Cap - $8 shipped S14 OEM Diff Bushings - $10 shipped KA24DE Oil Pump Drive, Key-way, and Bolt w/ washer - $15 shipped S13 Passenger Side Kick Panel - $18 shipped 240sx Shifter - $20 shipped 240sx Radiator Hold Down Brackets - $15 shipped per pair KA24DE Oil Filter Block Gasket OEM - $8 shipped KA24DE Throttle Body Gasket - $5 Shipped KA24DE Coolant Temp Sensor - $8 Shipped each S13 Radiator Bushings - $10 shipped per pair S13 89-90 Dash Connector Pigtail Chassis Side - $10 shipped KA24DE Flywheel Bolts - $20 shipped for 6 T25 Turbo Inlet Gasket - $5 Shipped KA24DE/E Throttle Position Sensor - $15 shipped KA24DE Spark Plug Clips Perfect Condition - $15 for all 4 shipped S13 Rear Side Marker Lights w/ harnesses - $15 shipped each S13 Hatchback Trunk Trim - $20 picked up ![]() S13 Front Crossmember - $60 picked up ![]() IMG_0728 by Dean Chinowith, on Flickr S13 Fusebox Bracket Engine Bay - $20 shipped ![]() IMG_0729 by Dean Chinowith, on Flickr S13 Power Window Glass - $20 Picked Up ![]() IMG_0731 by Dean Chinowith, on Flickr S13 Hatchback Tail Light Garnish - $20 picked up ![]() IMG_0732 by Dean Chinowith, on Flickr 91-94 S13 Dash Harness Pigtail (Chassis Side) - $15 shipped ![]() IMG_0733 by Dean Chinowith, on Flickr KA24DE 5-Spd Transmission Gussets - $35 shipped (Only because they're heavy) ![]() IMG_0737 by Dean Chinowith, on Flickr S13 Hatchback Tail Lights - $80 shipped ![]() IMG_0738 by Dean Chinowith, on Flickr S13 E-Brake Cables in good shape - $45 shipped 240sx Throttle Cable - $30 shipped S14 Auto Shifter Lock Cable - $15 shipped ![]() IMG_0740 by Dean Chinowith, on Flickr S13 Under Steering Wheel Dash Panel - $25 shipped S13 Hatchback B-Pillar Exterior Trim L + R - $20 shipped ![]() IMG_0747 by Dean Chinowith, on Flickr -S14 OEM Rear Sway Bar - $60 plus shipping -S14 OEM Suspension (great shape, 80,000 miles) - $40 plus shipping - S13 Headlights Brackets - 40 shipped ![]() IMG_0314 by Dean Chinowith, on Flickr Last edited by drifter92; 03-02-2014 at 07:53 PM.. |
