Old 10-31-2009, 02:35 PM   #2401
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
Slow down a little on your deposition rate. The "dimes" should be tighter.
You can see on the merge collector. There are little eyelets (tiny tiny little pin holes). They're fully sealed, but they will be more prone to cracking. Especially under a 10 or 9 second scenario.
Just slow down a bit and add the filler more often.
But it still looks good! Keep it up!
atutt is offline   Reply With Quote
Old 10-31-2009, 02:55 PM   #2402
[email protected]
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
that was a cover pass , the tight welds were on the first pass... second time around was with 1/16th rod and slow phat dimes..
S@nt0s is offline   Reply With Quote
Old 11-01-2009, 06:40 PM   #2403
[email protected]
S@nt0s's Avatar
today i attacked the intake manifold to weld the mustang flange for the 75mm TB....
went from this
to this..
Old 11-03-2009, 12:44 AM   #2404
STR8E180
STR8E180 is an unknown quantity at this point
nicely done ^
STR8E180 is offline   Reply With Quote
Old 11-03-2009, 05:46 AM   #2405
Otto347
Otto347's Avatar
Originally Posted by Jonnie Fraz View Post
I love this! Just a question why go with a taper and not drill the upright to 3/4"?
Good question, never really thought about that. Although the stock rear balljoint and S14 front spindles are so close to the 7° taper that it didnt take much effort to get them reamed.
Old 11-03-2009, 01:08 PM   #2406
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Picked up a pair of used Power MIG 215s. Also signed the lease to our 3200sf shop space..
I should have some better contributions to this thread soon. Need to make a materials rack, and a tire/wheel rack and quite a few equipment stands for grinders, bender, etc. Stoked!
MELLO*SOS is offline   Reply With Quote
Old 11-03-2009, 04:04 PM   #2407
atutt
atutt's Avatar
^Lincolns are good stuff. You won't be disappointed.. Maybe...
Congrats on the purchases!
Old 11-03-2009, 04:06 PM   #2408
S14_Kouki
S14_Kouki's Avatar
Hell yeah thats fucking awesome good luck with everything and great welders.
S14_Kouki is offline   Reply With Quote
Old 11-03-2009, 04:39 PM   #2409
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Thanks fellas. I setup one of the machines and ran some beads on some 1/8 mild square tubing. I was impressed by the power! The PM seems to have a bigger issue with burnback than I have ever had with my MM140. When I look at the gun/cup head on, the mig tip is not in the direct center, it's offset to one side. I might end up replacing the gun + hose + cup assembly and putting the old stuff on the other box. I can rotate the cup a little to re-align it to center but it doesn't stay there long.. Everything I have read says the PM215 is a great machine, a lot of guys seem really happy with them. First Lincoln I have used, my MIG and TIG are miller which I am extremely impressed with...
Either of you guys using a PM215? I was using Voltage "D" and WFS of 200-300, think I settled around 275... The chart on the box says D/240 for 1/8 mild with .035, I started there and fine tuned until it performed how I wanted.. Just adjusted based on sound and bead profile.
I also picked up a 5x10 welding table out of 4x4 stock, a 3x5x3 welding table, a 3x5x4 materials cart, a 10 foot chop saw table and chop saw, about a ton (literally) of raw materials, the 2 PM215s, a 4" grinder (can't have too many of those), a small rolling compressor and some other random tables, chairs etc. We pretty much bought out this welding shops equipment and materials... Good thing the lease went thru on the new unit or else I would have nowhere to store all these goodies hahaha
Old 11-04-2009, 10:22 AM   #2410
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
congrats mello! Can't wait to see some goodies pumped out with the additional equipment. Hit me up dude
Coolwhip is offline   Reply With Quote
Old 11-04-2009, 07:07 PM   #2411
BenArtM80
BenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to allBenArtM80 is a name known to all
well I know most of the stuff on here is welding, so I'll start with a downpipe I made a couple years ago for my s13 KA with a topmount setup. I just went to a muffler shop and picked up some scrap stuff with various bends and cut them and pieced it together to make it fit. Just mig'd it together....not great or pretty, but it fit well and worked great. Someone stole it from my house (along with my turbo and manifold) when my shell was sitting around, so if you've seen it or have it.....I really want it back....
Next is some fiberglass stuff I've done, a lip I made over the past few weeks and a spare radio din I turned into a gauge pod. For the lip, I made a mold from some foam board using the bottom of the bumper cover to mark an outline, laid it up with a few layers of glass and resin. Then added some evercoat fibertech for strength, finished with some polytech putty and rattlecan paint. All in all.....it cost more and took more time than I thought, but doesn't everything.
gauge din
BenArtM80 is offline   Reply With Quote
Old 11-05-2009, 01:14 AM   #2412
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Not sure if I've posted this yet. But had my dad make me a shifter for my NB on the lathe and then polished.
duffman1278 is offline   Reply With Quote
Old 11-05-2009, 08:28 AM   #2413
ka-titties
i made a nismo replica shifter on the lathe a few weeks back. i love it!
Old 11-08-2009, 10:19 PM   #2414
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Hi guys and gals. Sorry I haven't been posting much. I have been working 20 hour days building a new Camaro for Sema, and driver Conrad Grunewald for Formula D.
We won the coveted GM Design award for Best High Performance Product of SEMA 2009.
Pretty excited!
blu808 is offline   Reply With Quote
Old 11-08-2009, 10:31 PM   #2415
duffman1278
Stunning, well deserved. Congrats
Old 11-08-2009, 10:40 PM   #2416
nism014
nism014 is an unknown quantity at this point
Originally Posted by dsc4130 View Post
friends new intercooler setup i just did. built it out of pretty much nothing, has three and a half feet of I/C piping,and ive never seen a t28 spools sooo fast.
and it was stuuuuupid easy
Can anybody point me to a thread referencing an intercooler fitment like this one? I've searching for a while but can't find anything other than pictures.
I want to configure my fmic the same way and do the work myself, just want to get a basic idea before I take down my car and start wrenching.
what needs to be cut? welded? piping fitment? intercooler size?
nism014 is offline   Reply With Quote
Old 11-09-2009, 07:54 AM   #2417
roco
roco's Avatar
roco is an unknown quantity at this point
This is the full cage i fabricated for our Time Attack CRX race car for next season, its a 11point custom mandrell bent cage, to TA regs. we went for
minimum metal but maximum protection. its defnitly the tightest and best fitting
cage ive built to date.
"Racing is life. Everything else that happens before or after is just waiting." ~Steve McQueen [Le Mans -1970]
roco is offline   Reply With Quote
Old 11-09-2009, 02:40 PM   #2418
Firestorm
Firestorm's Avatar
Firestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond repute
Send a message via ICQ to Firestorm
luke, could you explain why that camaro has two radiators?
anyways, congratulations on the award.
Firestorm is offline   Reply With Quote
Old 11-09-2009, 05:32 PM   #2419
Z28ricer
Z28ricer is an unknown quantity at this point
My bet is that the rear one is a heat exchanger for water to air intercooler setup.
Z28ricer is offline   Reply With Quote
Old 11-09-2009, 05:45 PM   #2420
GSXRJJordan
GSXRJJordan's Avatar
Bingo.
In an event like drifting (or just about any racing), water-to-air is much more efficient way to cool the intake charge than air-to-air. When you add a huge heat exchanger and some airflow to the water, it gets even better. As far as being in the trunk, it's the only place left lol.
The car looks stunning in person, I'm lucky to have been a part of it - Luke and Conrad did a fantastic job, and deserve the Best Race Car award!
I'll have go get my finished wiring pics up in this thread
Old 11-10-2009, 07:20 AM   #2421
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
Originally Posted by Otto347 View Post
Modded my lower control arms for mono ball studs.
Finally got them on today but the car wont be mobile for a few more months.
hey otto, thanks for the info via PM. do you plan on doing this to the front lower control arms also??
compared to the BS roll center adjusters out there, doing what you've done is wayyyyyyy cheaper.
also, i FINALLY have something to contribute but didn't take pics yet..
i made my own nismo power brace for my S13. i'll post pics tonight or tomorrow.
clark is offline   Reply With Quote
Old 11-10-2009, 09:28 AM   #2422
conrad_s13.5
conrad_s13.5's Avatar
hey nismo014, theres really not all that much to it.
he took the IC and flipped it upside down, and put it in the core support right in front of the radiator.
the only custom fab work, is the mounting tabs, and for the piping. just have to either fab it up so the inlet/outlet are going straight back towards the motor, or if u can find a way to rig it with 90 degree couplers.
that camero is SICK BTW!!!!!!!!!!!!!!!
cONtRol FReAkS
Old 11-10-2009, 01:55 PM   #2423
CrazyTrance
CrazyTrance's Avatar
CrazyTrance is on a distinguished road
They are called mid-mount setups with the intercooler like that.
450sx.com
CrazyTrance is offline   Reply With Quote
Old 11-10-2009, 03:36 PM   #2424
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
What ya want: POWERED BY MAX: åâ€*·å´ãƒ‘ーツ Cooling
How to do it: POWERED BY MAX: Forums フォーラãƒ* / パーツショプMAXプ ãƒ*ダクトフォーãƒÂ ©ãƒ*Parts Shop MAX Products Forum / HMIC High Mount InterCooler with short pipe kit *update p.3*
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 11-11-2009, 02:47 PM   #2425
ballinnmiami240sx
ballinnmiami240sx's Avatar
ballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura about
My first cage build. This car will be getting a lot of work from me.
This car belongs to wishihadasilvia on here and is rocking a set of fortune 500 coilovers. On to the cage. I bought a mitler brothers bender a while back and a miller 211 mig to be able to build my own cages.
I still have to add a few more things to it. We are using the NASA and Formula d rule books to keep it within spec.
1994 FD3S Drift // 945garage // sumospeed.com
ballinnmiami240sx is offline   Reply With Quote
Old 11-12-2009, 05:28 AM   #2426
nism014
nice, thanks a lot!
Old 11-12-2009, 01:00 PM   #2427
mestizo
mestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the rough
Ok I guess it's time to throw a few pics of my car in here.
Jonnie Fraz did all of this work for me, we lowered my seat and made a harness bar for this Sunday's Thunderhill track day. This is just the latest work that Jonnie has done to my car, there is a lot more in my build thread.
Removing the stock seat mount.
Then we used a plasma cutter to slice the cat hump, next was a hammer to knock it down til it was just above the exhaust.
New seat mount partially finished.
Front seat mount all finished and the cat hump welded back together.
Then he made a fixed mount bracket for the seat so I could get the lowest seating position possible.
Just to give you an idea of what my seating position is now... I am 6'7", 285lbs and now I have about 6 inches of room above my head. My head actually touched the roof prior to this.
I got rid of my auto belts finally so Jon made me a harness bar, hopefully soon we can get a bender so we can cage the car.
92 S13 Coupe Track Car
mestizo is offline   Reply With Quote
Old 11-15-2009, 11:58 AM   #2428
sonomadrifter
sonomadrifter's Avatar
sonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the rough
I love this thread, keep up the good work guys.
Heres my contribution:
After last event it blistered the tires from rubbing the inner fenders and around, on the 9J with a 215:
And I wanted to run much larger tires and wheels and go lower than that.
SO, while the motor was out I went and tubbed it, 16 gauge, about $30 in sheet metal.
Near end result:
The ends tuck in for the IC pipes.
NEXT,
was the oil cooler I picked up for cheap by Yamato Garage. But because it was large it wouldnt fit quite where I hoped up front where the stock fogs go. And I didnt want to bury it inbetween the rad and front mount because of over heating and I still have AC so I didnt want to stack four coolers on top of each other and suffer down the road.
My front mount is way too large but I couldnt afford to buy anything new and the one piece custom IC piping was to hard to part with. Because of that it used to look like this with cut bumper support, pretty weak.
So in attempt to do the two birds with one stone thing I made a bash bar with some seamless tubing that was lying around the shop. I had to rewire the blinkers up front to my body lights beside the headlights to pass inspection and this, athough ugly, gives lots of function by direct air from where the blinkers once were to the cooler.
I used the stock mounts so it can be bolted on and off, and can still go back to stock if I ever want.
This last week I also went to the junkyard and happened to stumble across a Mistu Montero SUV with a lovley PS cooler, so I yanked it for nine bucks and its going on the otherside of the front mount once I make some brackets.
All major final welding is done by my brother, I just make it and tack it together. The car should leave the shop this week if I get all the little things worked out next weekend. Sorry for the long, mistake filled post.
sonomadrifter is offline   Reply With Quote
Old 11-15-2009, 09:00 PM   #2429
Otto347
Otto347's Avatar
^^Those tubs look great!
Old 11-15-2009, 10:18 PM   #2430
Devil Man
Devil Man is an unknown quantity at this point
dude wow your tubs look really good and amazing job with lowering the seat too!
not to be a dick, but to be a dick....
Devil Man is offline   Reply With Quote
