![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
SpeedSport/RPS Single and Twin Carbon-Carbon Clutches for SR20/KA24!! MVP Motorsports
![]() The SR20 and KA24 Single disc Carbon clutch is designed around the factory kit that has been modified to hold 400ft/lbs of torque. They replace the steel friction ring with a billet aluminum ring. Offering both a steel and aluminum flywheel. The steel flywheel's weight is light enough to notice an improvement in acceleration but not too light for street use. The aluminum flywheel is for Racecars and street use for those that do not mind a lot of extra gear noise. This clutch is fully rebuildable by the customer or the shop doing the work. All you need it the serial number off the back of the flywheel and a rebuild kit for that number from SpeedSport. ![]() The SR20 and KA24 8.5" Twin disc Carbon clutch uses a Billet "Strapless" cover which is rated for 800ft/lbs of torque. They offer Steel and Aluminum flywheels. This clutch is designed for heavy Drag and Road Racing. The Steel flywheel is designed for the Street and Drag Stripe and the Aluminum one is for hard core Road Racing. The aluminum flywheel is for Racecars and street use for those that do not mind a lot of extra gear noise. This clutch is fully rebuildable. For a rebuild you will need a RGA# to send the clutch in to get rebuilt. Rebuilds sent in usually take 1-2 weeks from when they are received to be shipped back out. PM OR POST UP FOR ZILVIA.NET PRICING!!! Regards, Robert
940-683-8282 x20 Robert Del Angel CLICK HERE FOR OUR FACEBOOK PAGE!!! FOLLOW US ON TWITTER!!! Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!! |
PM's replied!
Regards, Robert
PM's replied!
Regards, Robert
Bump!
Regards, Robert
PM's replied!
Regards, Robert
Bump!
Regards, Robert
PM's replied!
Regards, Robert
Bump!!
Regards, Robert
Bump!
Regards, Robert
