my car sound like a wrx
i finshing my s14 sr swap in my 97 s14 and i having some issues. first the car has a miss sound like a wrx. i pin point that the 4th coilpack is not firing right weak signal. i have power to the igntior but weak signal coming out of the 4 th coil. so my friend came by with his s14 with s14sr swap and i check the ignitor and it sound like mine. then i connect his back up and when he started up again he still having the same problem.
i check all his coil and all has power, i check the injectors and it has power. need help. any positive feedback will helpful |
![]() Join Date: Jan 2008
i like the sound of the WRX haha.... try replacing the coil pack
My Twin Scroll Gt30r Sr22det Build |
#10 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
My KA24E sounded like one but thats a whole different ball game... Oddly enough I just needed to add oil... Sounds REALLY dumb but check your oil.
![]() Join Date: Dec 2006
Check fuel injector clips and spark
Isolate the dead cylinder by pulling Coil packs one by one When unplugging the coil if no change occurs then thats your problem cylinder If you find the problem coil, swap it in to another cylinder if it follows then that coil pack is bad
![]() Join Date: Oct 2007
My girlfriends R32 had this problem a couple of times. Turned out to be 2 separate coilpacks had bunked out on her.
Blow me, bitches.
#20 |
#21 |
Once you checked all that and if you have no progress try swapping the ECU or check the signal to that injector. I assume you already swapped the plugs.
#22 | |
Your compression is Wayyyy low minimum is like 129psi did you pull all the plugs and crank the engine WOT until the needle stops rising?? If you did drop a little bit of oil in the cylinders if compression improves then your Rings are bad
#23 | ||
i also swapped ecu and disconnect the battery and nothing. same thing Quote:
#26 |
so if i understand this correctly. After you swapped out the coilpack for your friends car(which was runing fine) and put it back, his car has the same problem and sounds like a wrx now. So both your cars have the same problem. You should double check the connector for the coilpack. Maybe when you pulled out the connector for your car or your friends, you messed up the connector. I had the same problem when i was working on a limo. The connector got power but it was'nt grounded correctly so everytime i put a new coilpack in, it shorted out and fried the coilpack. So i would double check the connector to make sure its not shorted out. This could be the reason your friends car is not running right either if you fried his coilpack. Im pretty sure once you find the short your problems will be gone. My bet is the connector that plugs into the coilpack,just replace it. Good luck.
Drunk posting FTW!
#27 |
![]() ![]() ![]() ![]() Feedback Score: 9 reviews
Sounds like it fried the coilpack as stated buy zugoi...
TW: #/f/cars-sale/390459...d9s-coils.html |
#28 | |
#29 |
i found the problem the one wire that was extended came loose going into the ignitor. i check the the coil for power and i thought i did but there are 3 black wire on #1 cyl. so i soildered it and it is fix now
![]() . thanks to all for info |
