![]() Join Date: May 2010
Any idea what would cause the throttle to do this?
http://youtu.be/u6sFCKGWvHI
Throttle acts like I'm getting on the gas when I'm not, in pulses. Happens at low rpm low load, inability to cruise unless at around 3500 rpm |
I had a similar problem with my 300na 1990. It was the right hand o2 sensor. It would run terrible with throttle just cracked, but wuld run sweet above 3k, about 67 mph.
