Can't seem to find anything on this ANYWHERE. Looking for the bolts that hold the outside of the headlight to the fender. One side slides into the headlight and the other bolts on to the fender. Anyone know what these are called for an easy way to find???
![]() Join Date: Dec 2006
You talking about the side thats behind the corner marker?
If so both sides have studs in the headlight on that side and use 10mm nuts to secure to the fender. Yours are probably snapped off which is a common issue. probably have to drill out the stud "Tap" a hole and use 10mm bolts
| bolts, headlight, silvia |
