#843 | |
It's Always Broken.
![]() Join Date: Feb 2010
Didn't really know where to post this question other than here.
When you guys are relocating your fusebox to the glovebox (s13) or where the airbag was (s14), what are you doing with your fuse box power wires that plug into the lower tranny harness and the EFI plugs?
#844 |
The fusebox will still need battery power, no matter where it is. As far as "EFI Plugs", do you mean the S13's plugs to the engine harness? For S13 just turn them around and run them back into the passenger footwell area. For S14, that stuff all changes, but you're still passing all the power/triggers through the M63/F3 plug anyway.
#846 | ||
It's Always Broken.
And yeah I meant the plugs that go to the engine harness. The brown one and gray one. Thanks
#847 |
You still need to connect to the trans harness, although you can change the alternator and starter solenoid wiring if you want to get fancy and lose those two useless connectors.
#848 |
What wire do you guys recommend to extend the injector wires? I'm trying to run the harness through the manifold. Will I have to extend anything else?
#849 |
![]() Join Date: Jun 2010
same gauge as stock wire. I forgot size I recently did mine. I also extended the CAS and MAF at the same time, ran the maf behind the motor. you might have to extend the cas
#850 |
I'm having trouble finding the size, and any idea on how long to extend the wires?
#851 | |
20ga wire is fine, stock is 18ga for injectors.
#852 |
Stock KA24DE
#854 |
![]() Join Date: Aug 2009
im not the best at reading wire schematics but looking at the FSM (EL-21) can i remove the 4 Retract Relays and get rid of all that wiring that runs to them. I have a Silvia front and really want to clean up the main harness going across the front end.
I have already removed the plugs/wire for the headlight motors.
Check Out My S13 Build |
#855 | |
I think the overall length from under the manifold to the injector is about 7" on my KA stuff. Easy enough to measure...
#856 |
Alright. Thanks a bunch. This is going to git rid of a lot of useless wires.
#857 |
Started my full tuck.
#858 |
i like the way it looks simple. what parts should i remove and tuck something around the bay? semi wire tuck.
#859 |
Besides the engine harness, the chassis harness/fusebox/relay box and battery are the big ones.
#861 |
Yup, they are wrapped. Been doing bit by bit and placing things where I want them as I go. Tomorrow it will be complete. Only thing on the sides now are headlight wires. Harness ran across the dash and over to glove box. Lower engine harness comes through the tranny tunnel. Not as clean as the others I have seen, but it gets the job done.
#862 |
![]() Join Date: Feb 2008
Excuse the not painted-ness... this is my engine harness. the chassis comes out on the sides just like EVOVIII808 did. this is also before i built the new core support and lower rad support..
#863 |
Would this hidden under the radiator support be sufficient for cooling an SR?
Griffin Aluminum Drag Race Radiators 2-55185-XC - SummitRacing.com I would go with the radiator option that uses an in-line filler neck, but other than that it would be identical to the kit above. Another shroud option is this one made by Flex-a-lite. |
#866 |
Yeah that'll do fine, especially if it's ducted from the bumper inlet to the radiator.
Tek18b_Jimmy, your engine harness looks solid, but is that white heat shrink at the ends of your FR braided loom just normal polyolefin stuff, or adhesive-lined? That loom will pull out of the heat shrink over time with vibration if you didn't use adhesive heat shrink.
#867 |
Thanks GSXRJJORDAN- unfortunatly i didnt know about the sticky shrink tube in white when i did it. so i electrical taped the ends of the loom to the wire clusters, then used heat shrink on it. if need be, i will find the sticky kind of white heat shrink and de-pin at the connectors and try again.
i did pull on the loom and it didn't really want to pull through the heat shrink. |
