Will auto trans mount work for a 5 spd trans?
As title states, I'm wondering if the automatic transmission mount will work with a manual transmission also.
Thanks
Looking for an s13 coupe in GA |
![]() Join Date: Dec 2002
Yes. However visually inspect it, most auto mounts are slightly more worn due to the added weight. You'd be surprised what a new mount looks like compared to the old, caved in one on your car.
#6 | |
Use construction grade sealant if you don't want things to rattle around as much. Use construction grade adhesive if you don't really care about things rattling around.
Do need the Factory Service Manual? Click here. |
