from Canada, eh!
![]() Join Date: Sep 2001
Hey guys!
I began Solo2 (Auto-X) in my area this year. Thus far, I have always finished next to last in my category, which is the highest street category. I'm currently running a midly modded SR powered 240sx. I have EBC pads, SS brake lines, Motul Fluid, AGX+ Ground Control (425-375lb), S15 T28, on 215-235 Potenza's. Now, when I get at the track, I set the AGX to 3 and 8, bring the pressure up to 40 psi all around, lower the boost to 7 psi to do my runs. I need help from you guys that have more experience. Usually, on a run, I gun it at the beginning, shift into second and stay in second during the whole run. Should I be switching gears from 1rst to 2nd often or it will make me lose more time? As for attacking corners: I know grip driving is the best, but should I try to power my way out of a corner with throttle induced oversteer? As for keeping the power constant... The Sr is such a nervous engine, it's always very hard to gage the throttle. My car jumps forward at the slightest touch and is slow when out of boost. Do you have any tips to keep the power under my foot (keeping boost) and tips to drive smoothly with this engine? Actually, any tips would be helpfull. I know that R-compounds will help me a lot (next year, i want to learn how to push my car with street compounds first) and that seat time is the best teacher. I just want to hear about your techniques so that I might be able to shave a few seconds off my runs.
-> HaLo Race Car: '98 E36 BMW M3 Daily Driver: '08 Fiji Blue Honda Civic Si SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#2 | |||||||
Autox Technician
![]() Join Date: Dec 2001
Re: Driving tips and tricks?
You're not running in a novice class?? The Street Modified class can be very competative (although some areas I hear are pretty weak). Anyways, it sounds like you've got a decent car, but what Potenza's are you using?? RE750's?? I can imagine traction might be a problem with those, esp. with narrow tires (215 becomes narrow in the SM class). FWIW: my street tires are 235/ 245 Goodyear Eagle F1's (200 treadwear). My Victoracers are 245/245. Quote:
Oh man.... R- compounds are a whole different animal. You'll be re-learning the car all over again!! ![]() Quote:
I've driven a few Sentras (SR20DE) and have shifted into 1st a few times, but even in those keeping it in 2nd is smoother (and ultimately faster). You just might have to re-work your line thinking about if you're going to be lugging in 2nd. Quote:
is it possible to put a bit of slack into the throttle cable?? otherwise, just ease onto the throttle as smoothly as possible. Quote:
Keep an eye on your hand positioning. I was at an autocross with a bunch of Sentra guys and noticed the biggest problem was people crossing their hands and keeping them close together at the top of the wheel (which leaves you yanking the wheel instead of turning it). Drive as smoothly as possible. Harsh throttle and steering inputs just make the car go where it wants, instead of where you want. Finding a better line through corners often makes you faster than pressing the gas more. Hopefully some other guys can add to this or comments where necessary. Good luck!
![]() Join Date: Mar 2002
on autoXes...
focus your eyes on the next set of turns instead of the turn you're at so you can positioned the car better when entering the next remaining turns.. feather gas pedal, brake BEFORE the turn, smoothness is the key and go with grip all the way if you can.. try to avoid what we called "drifting"(unless if you just want to have fun around the course) but me personally, i never did any drifting on purpose at any of my autoXes.. try to stay on the "line" like ace mentioned stay with 2nd gear sometimes i get into 1st (downshifting+heel and toe) on hairpins and sometimes i can get into 3rd on short straightaways (maybe because of my 4.683 2 way diff) im still sporting a 100%stock ka and i have some suspension mods+fm901's.. and im doing pretty good.. i can hang with the big boys and beat some of them good luck, im sure you'll get the hang of it
![]() ==>>TGL GARAGE<<==.. RIP! S13 coupe KA-T @ 0.5 Bar = SOLD! A31 Cefiro + SR = Current |
#4 | ||||||||||||
from Canada, eh!
Re: Re: Driving tips and tricks?
First off, I'd like to thank you for your tips and comments. It's very appreciated. I don't have a lot of input from fellow 240sx drivers in my area (because they don't Auto-X!!!!)...
My Potenzas are RE01 in rear and RE711 in front. It's the equivalent of the RE730. I have very good traction with them for street driving and I have gotten the hang of them for auto-x. I can't really shove wider tires in front without getting some spacers. Quote:
![]() Quote:
![]() Quote:
![]() Quote:
![]() Quote:
The moment I enter one gate, my eyes are on the next one or the next 2 ones. Quote:
My next event is this sunday. I hope to fare well. I am getting better, but my category is very competitive... I'll keep you guys posted. Any more input is welcomed.
This may sound silly, but try to ride with more experienced drivers. You'll be surprised what you'll learn. You won't be concentrating on driving so you'll have a chance to compare the lines that you drive with those of a veteran.
#6 | ||||
Autox Technician
Late braking will usually make you slower at the corner exit... especially with the SR, you might want to be braking earlier so you can start accelerating earlier (maybe a bit of that power-on oversteer). Quote:
I try to not heel-toe downshift at autoxes, although I do it a lot on the streets (using the side of my foot instead of the heel). What I'll do if I need to downshift (usually when driving an underpowered car such as a Sentra) is just get the shift done early. Brake with the clutch in and shift to neutral, turn in while getting off the brake, rev match through the turn, get it in gear and be accelerating by the corner exit. If possible I'll even have it in the lower gear before the turn in. Basically, I just try to keep things simple. Complicating things (especially for drivers without a lot of [a few decades of] experience) usually hurts more than helps. If you're in your first year (or worse, your second year) and you aren't doing so great, don't sweat it. Seat time is pretty much the only thing that will make you a better driver. Knowing the techniques is a part of it, but they aren't any good if you aren't putting them to use and learning how to use them best. You WILL get better as time goes by, so keep on autoxing!
from Canada, eh!
Well guys, as promised... the results of my last weekend event.
I'd like to thank you for your inputs, because they HELPED A LOT! I marked down the tires and after my first run, I passed my hand on each tire to check their warmth. Seems that 40 psi all around with my car wasn't a great idea: 40-35 was the best with my setup and the car felt much more neutral! Very happy with that. Also, we ran a very rapid course with 2 sections you had to downshift in 1rst. I'm satisfied with that too... Now for the results: Keep in mind this is my 4th event, and only 3rd with my 240sx. I finished second to last with my 240sx everytime with SM class running around 11-15 people. Well boys, I finished 9th on 13 beating regulars (with at least 2 years experience). I'm utterly satisfied. I really felt I improved today and I must admit that Bbandit and AceInHole really helped out on this one. Thanks a lot guys, my next event is in 2 weeks and I'll be sure to tell you how it goes.
Autox Technician
That's great that you were able to improve!!
What happens a lot of the time, though, is you improve rapidly over a few events, then hit a wall, and stay there for a long time (some people hit their "wall" earlier.... some later). Seems like all you needed was an edge to get you over the first "wall". Let's look for a 6th place next time maybe?? As for me... I've got the last event of the season coming up. Whoever wins this event, wins the season championship, and my co-driver (Jeff of www.jmcn.com) has bested me over the last 2 events. I've got very little time to get some improving done myself ![]()
![]() Join Date: Oct 2001
How well you do in SM depends on the other drivers, because your car is way outclassed.
I would see how your times compare to people in street touring, because that is realisticly the level your car is at, even though the engine swap puts you in SM. |
#12 | |
Autox Technician
![]() Join Date: Jul 2002
His suspension still needs some development. He says he is turning the boost down to 7 psi to be able to handle the car. That's no good. Gotta be able to use the power of the SR, especially with the T28 already on it. The turbo should be spooling up really quick, which is great. His power is there, just needs some help harnessing it. The AGX shocks are OK, but not great. What spring rates are you running? Your car's biggest deficiency I see right now are the tires. You said you might go with Yoko A032r? I would suggest you try Kumho victoracers instead. Yokos are a bit harder than the kumhos. And besides, kunhos are relatively cheap compared to some (hoosier) tires.
You said you are already looking ahead but you said when you get to a gate you look to the next one. Might I suggest you try your best to look two gates ahead. The gate you are in should have been set up for two gates beforehand and therefore no visual reference into it is needed. This is the hardest thing to learn. You can never look too far ahead. Consider every corner as setting up for the next two corners. You've got a great engine combo, you just need to get your suspension dialed in to handle the available horsepower so you can stop turning down the boost. Hope this rambling mess made sense to you and good luck at your next event.
Allen Delta Region SCCA SM 1990 240SX SR20DET |
you dont need R compounds right now.
Until you can drive consistantly and you need 1-2 seconds to beat the leader...thats when you could possibly make use of R compounds. No offense intented, but right now I just see "Help, I flatspotted my Hooiser's!" threads in your future. They are like everyone said, very different tires. I think learning how to drive clean, smooth events is more usefull than throwing money at the problem. |
from Canada, eh!
Actually, my car has 2 defiencies:
1. driver 2. tires Right now, I'm simply starting. That is why I make mistakes, I'm not too quick and I can't seem to handle the car very well. My spring rate is very hard: 425lb/in in front, 375lb/in rear. I have to master the car the way it is, then get some R compounds. I know I can't be competitive as of now in my class. In my area, no one in my class runs street tires and have less than 2 years of autoX experience. I run street tires and have 3 events of experience. I'm at a disadvantage. Heck, I should be dead last. But I'm not and that really helps my morale. ![]() I'm also very happy because for the very first time, I was able to handle 10 psi of boost and get better times with it. I'll be posting more to give you details about my progression. After all, I'm the only 240sx in my area running regularly in autoX events.
#16 | ||||
Autox Technician
we'll have to expect you to progress very rapidly from now on ![]() Quote:
As for progression.... i'm in my first year out of Novice and just won the last race of the season (well, points event), unofficially becoming the Street Mod season champ for the NER region (over my co-driver Jeff). Maybe we'll see the same out of you in a year or so?? Then we can all meet at Nationals ![]() Anyways.... i forgot to mention walking the course. Sometimes you can go through a day improving on your times run after run, but only because each run tells you something about how you should take certain turns, and when to be on the brake, throttle, or even clutch. the more of that you can get done during the walk through, the less runs (precious, precious runs) you'll spend on "learning" how to drive the course. Although.... it's sort of hard to explain how to go through a walk through since everyone will walk the course their own way. There WAS a pretty decent article in a recent issue of SportsCar though.....
#17 | |
WOW addicted
Those rates seem kinda high for AGX's.. I agree throwing money at the car is not the answer yet. More seat time. Get all you can from the car. Then get some one better than you to drive it. If they are running similar times, then it's usually hardware limiting you. If its driver, obviously they will be faster.
this works b/c we often 'think' we've found the limits of our car, and really haven't. Getting a second opinion almost always opens your eyes a bit.
#19 |
from Canada, eh!
Ace:
Well, don't get your hopes too high on me... I would love to win a few events, but I still believe I'm a few years from that... AS for walking the course, I usually walk it 2-3 times before the event starts. Afterwards, I walk the course on the side, watching how the others tackle the corners and the gates. That really helps a lot.MovinUp-1: I just got the rear springs. I had some 250lbs in the back and the car understeered way too much. Right now, it's much more balance and by playing with tire pressure and AGX damping, I can actually get the car to be very neutral. Sykikchimp: The problem is that in our area, we are not allowed to let another driver sit or drive our car for a run. The obvious reason is that it gives an advantage to the person that's sitting in the car... I'm actually getting some second opinions here which are very eye-opening and useful. That is why I love this forum so much! Espacially this section! ![]()
#21 | |
from Canada, eh!
#22 |
Autox Technician
Our region has an instructor program where an instructor can go along for a ride to help point things out. It REALLY helps a lot. It also helps to have a co-driver some events to get a second opinion on the car, and it's even better if the co-driver is better than (or at least as good as) you so you can see what the car is really capable of and have a goal to get to.
My co-driver and I constantly discuss what the car should be doing on what section. Lately it's been "oh man... we can get like another full second from the car..." (which has been set up and tuned beautifully for a smoother powerband thanks to some help from CIP). Part of that is the walk-through, part is while spectating other drivers on the course, and part is during our heat while we're taking runs. I break the course down into sections which are approached differently. This makes it a lot easier to improve your times through the day, because you'll know after a run or two where the key to the course is. There's almost ALWAYS one, or maybe two, key section(s) that if done right, will guarantee a good time, and if screwed up, will demolish your run, even if you're not completely "on" for the rest of the course. You can try to see what sections are on the throttle more, and where you can try to build up more speed by going through a previous section slower. Or you can see what sections are slow, so if you're coming out of a previous sections slower than you might want to it won't hurt as much, and maybe you can get a better line into the next section. At first within the sections, you're not really worried about where you are, mostly just how you're entering and exiting. From there you have your general line and can build from there to shave off the important tenths and hudreths of seconds. Otherwise you might be stuck just trying to fine tune sections that you're approaching wrong, working on the little stuff while you can be dropping times a lot more if you just look at how you're taking the sections (or course) as a whole. I like to try and break the course down further so that I'm only using key cones, too. Sometimes there will be a lot of useless cones that you don't need to get close to, or worry about at all. Looking at fewer cones, you set some points where the car has to be positioned a certain way, and it gets a bit easier to drive the line to meet that position. It also keeps you looking further ahead, as you zone out the unimportant gates and look further for the next key cone or gate.
#23 | |
![]() Join Date: Nov 2001
Adam '89 coupe KA24DE+T 14.1 @ 104 MPH '88 Celica All-Trac turbo stock, but no more ecu codes!! |
#24 | |
Autox Technician
I usually try not to go hand over hand at any time during an autocross run. I think you get more control sort of "shimmying" the wheel, but I thought there was a debate on that a while back on zilvia.
#25 |
WOW addicted
If I am going into a tight corner, I always "shuffle steer" to keep from getting crossed up. Getting crossed up is bad.. it's hard to make small adjustments to your line when your all crossed up.
#26 |
sounds like the way you would want to do it. It's hard to get out of the habit of palm steering from my days of driving in snow. Now I have to stop crossing up. Oh well, looks like I'm running an auto-x at the end of september. Too bad the 240 isn't running and I have to drive my new '88 celica alltrac turbo instead. Oh well, the 240 drives like crap anyway, it needs some springs and dampers.
#27 |
from Canada, eh!
Wow! Too much info! :P Must try this this weekend!
I'll keep you posted.As for my hand positionning, it's between 10-2 and 9-3. ![]()
#28 | |
WOW addicted
basically just try to keep hands near the 10.5-2.5 area while turning.
