Help with VLSD rear cover
Hi guys,
I picked up a VLSD out of a 92 HICAS car for my open diff'd 89 coupe. Its only the differential not the pumpkin. Do I need a rear cover from a VLSD equipped car to put on my open diff pumpkin? Will a cover from a NA (R200) 300zx work? Thanks, Dan |
Any cover should work - not sure about the z32 one though, never tried it. The VLSD cover has cooling fins, that's about the only physical difference when compared to open diff covers.
91-94 covers have 4 bolt studs 95-98 have 2 bolt studs the z32 and j30 rear covers are also 2 bolt studs as well. just use your cover off of your open diff that your using on your car now.
