Fuel system troubleshoot?
Whats up guys? I recently picked up a s13 coupe and she seems to guzzle the gas. I Filled the tank The otherday, drove almost 200 miles and I'm now below empty. No engine mods either. Just a straight pipe from the cat back. Any suggestions? Clean air filter cleaned maf, changed oil+stabilizer plugs are good too.
Hmm. Seems as if the leak is coming from the injectors. I was Just going over the fuel system and I found that 3 of my 4 injectors fall out of resistance specs. Think this might be a result of the straight pipe and back pressure issues?
Most likely just old worn out injectors. Mine are like that now.
#6 | |
