![]() Join Date: Feb 2002
Enjuku Racing - Street Faction Rear Bash Bar S14
Street Faction Rear Bash Bar for Nissan 240sx S14 95-98 ![]() Our bash bars are designed by a certified aerospace TIG welder. Each of our bars are constructed using thick mild-steel tubing that is bent on a digitally calibrated tubing bender. All of our bars come powdercoated to prevent chipping & rusting. The advantages of using Street Faction's bash bars include: Bolt-on replacement for the OEM crash beam Bolts onto OEM location using factory hardware Clears signal lights, unlike other bolt-on bash bars Supports aftermarket aero bumpers/kits TIG welded Weight savings Each basic bar is modular, so we can add options such as: Jack Point (saves time by quickly jacking up your car) License Plate Mount (proper way to mount your plate without using zip-ties) Tow Hook Mount (to pull your vehicle) Disclaimer: Our bash bars are not guaranteed to fit cars that have previously been in a front-end accident. Bash bars have not been tested on every bumper, so some trimming may be required. Our bars are made to order, so please allow anywhere between 1-3 weeks for each bar to be shipped out. In Stock and Ready to Ship! $175 + Options
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
Street Factions products are top notch! The only 100% tested and confirmed bash bar to fit under OE S13 Aero Bumpers with zero clearance issues! I personally run one of their bars on my hatchback and I can easily speak for the quality of the build... Haven't seen many other bash bars on the market that are as clean and well built as theirs. Buy in confidence that you are getting an amazing product.
