Peak Performance Rear Toe Doesn't Fit???
Guys, I'm doom.
I was with my mechanic to install coilover/ruca/rear toe on my s14zenki. RUCA is fine, but rear toe is play because the spacer is short. I have attached the picture comparing to the stock. It isn't snug into the subframe.... measure stock one Measure peak performance Any peak performance users have the same problem or your rear toe perfectly fit? Please suggest, thanks |
![]() Join Date: Nov 2005
maybe you gotta bend the top black part....dont know!
or they give you a tension rod instead of a toe!..
[email protected] TIRE CENTRAL "DONALD" 626-227-0150 DRIFT SPEED "QUOC" 562-342-9000 |
s13/s14 have different size spacers.
you got s13 ones. Solution: Washer or get correct size spacer. |
And your ruca's went in fine huhh, maybe they just sent you the wrong ones. Just contact peaks or the place you bought em & get the right ones.
I just installed mine last week Friday, sorry for the crap pics, doodoo camera, hope these help Toe rod spacers RUCA's spacers |
