![]() Join Date: Jul 2003
Trader Rating: (357)
Imported from Japan - these are fitted to the S15 SILVIA Spec R.
I have modified these bars and made a custom installation kit to be a direct bolt on install for S14 models here in the USA. Allows full access to the spare tire well and false floor. Locks together the rear frame rails to add chassis stiffness and reduce body flex. Genuine NISSAN S15 SILVIA Spec R Trunk Brace End brackets are welded to cross bar for solid, single piece fitment freshly powder coated bright silver 4x custom CNC spacers 4x 10.9 Grade Bolts w. extended length for secure install Nismo sticker because reasons Install guide w. torque specifications $OLD OUT ![]() ![]() ![]() ![]() ![]() Last edited by Bernie (NoVA); 10-07-2019 at 07:38 AM.. |
#6 | |
All PMs replied Last edited by Bernie (NoVA); 04-16-2018 at 02:34 PM.. |
![]() Join Date: May 2005
Would be dope to have full set. Sure can get machined. Getting a little tired of seeing upper Carbin Steel white bar. Like this OEM look application much more then maybe i can replace it with a Cusco carbon lower bar below the shock tower.
#17 |
![]() Join Date: Jun 2010
Trader Rating: (32)
![]() Feedback Score: 32 reviews
This is so awesome! I've always been curious if they would fit in a S14 myself.. Glad you confirmed that!! I got a GTSPEC Trunk Brace back in the day when they used to make them for my S13!! The stiffening enhancement was superb!
#27 |
This bar is beautiful, I really love the silver finish. Install is a breeze, especially with the installation guide with torque specifications, that Bernie supplies. Legit seller.
