Old 08-09-2009, 12:01 AM   #1
FruntFlip850
FruntFlip850's Avatar
FruntFlip850 is an unknown quantity at this point
Sr20det not starting!
Basically this is my situation. When I try to crank the motor all I get is a click it doesn't even turn over. Somehow my starter isn't powering up. I took the starter to get tested and its perfectly fine. I can still start the car by push starting but thats a bitch. My battery is fine and my alternator is still keeping it charged. Just can't seem to figure it out. Any ideas and help would be appreciated.
FruntFlip850 is offline   Reply With Quote
Old 08-09-2009, 01:25 AM   #2
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
one click? sounds like the solenoid.
flip3d is offline   Reply With Quote
Old 08-09-2009, 10:06 AM   #3
FruntFlip850
the click seems to be coming from the acc relay. not the solenoid. i even tried my brothers starter from his 240. i checked all fuses and relays. this is
Old 08-09-2009, 10:15 AM   #4
gunmetalr32
gunmetalr32's Avatar
gunmetalr32 is on a distinguished road
try giving the starter power
NEED S14 KOUKI VALANCES, S14 NAVAN SIDE SKIRTS, S14 KOUKI OEM JDM LIP HIT ME UP!!
gunmetalr32 is offline   Reply With Quote
Old 08-09-2009, 03:22 PM   #5
dub40sx
Sounds crazy as fuck but Ive had the exact same issue because of a simple ground not being hooked up. Theres one under the dash near the ECU. I apparently didnt remember to hook it up and i turn it and CLICK. Im not saying this is your issue but some stupid shit will make big problems sometimes.
Old 08-09-2009, 11:57 PM   #6
FruntFlip850
I mean i drove the car to work and when i got off it wouldn't start so i push started it and drove home. something could have came loose im sure. i put direct power to the starter and it started up but didn't crank the motor. something has to be stopping the connection just can't find it. I'll check that ground under the ecu tomorrow. just out of options on which thing to check next.
Old 09-23-2009, 04:49 PM   #7
woolman82
woolman82 is an unknown quantity at this point
Were you able to find the problem? I am stumped on my car. I replaced the starter with a brand new one, and all I get is a click. I've checked for power and everything else I can think of. Please let me know what you found. Thanx
woolman82 is offline   Reply With Quote
