![]() Join Date: Dec 2009
This weekend I did a motor swap and everything went well except the driveshaft. The KA driveshaft won't button up to the SR tranny so smoothly. There is about 1 1/2 inches that still pertrudes from the transmission and the damn thing just won't go in any further.
It also doesn't help that I have a J30 diff that is 3/4 of an inch longer than that of the original KA diff. What would be my possible solutions? Is there any way I could come a cross an SR yoke that would slide in the butt of the tranny just right? |
![]() Join Date: Dec 2002
SR vs KA are the same length, the only difference is ABS vs non ABS. If the dust collar has been removed you will see some of the shaft visible when installed, it's not meant to sit flush against the tail section. If it did you'd wear the rear seal out in a few hundred miles.
Maybe a picture might help, but a small amount of visible spline section is normal.
would the extra visible shaft be the cause of possible leaks at the rear output seal cause in reality there is nothing holding it in place.
Now that I think this is settled my next problem is that I replaced the old diff with a j30 diff. The diff is .75 inches longer than that of the stock shaft. the drive shaft won't line up now because the length from the ouput shaft to the diff is shorter than the actual driveshaft. |
The seal doesn't care where the driveshaft sits, as long as it's tight against it. It's pressed into the tail section, so it is held in place. It does not need to sit flush against the flange though, that will wear. Look at a crank seal, the crank sticks out past the seal a little, but the tension from the seal keeps it tight on the crank as it rotates. The driveshaft is the same way, the seal just fits snug around it, but if the shaft is too long the flange sits flat against the seal's facing edge, this will chew it up and cause leaks.
The J30 diff is an ABS unit, so you would need the shorter ABS driveshaft, though there are tons of threads on here, many I've replied to, where people have successfully used the non ABS shaft, it's just a tighter fit. The overall drivleine can be adjusted a hair between the crossmember, engine and transmission mounts, subframe, and diff mounts. I ran a non ABS shaft with an ABS diff for over eight years in my second car and it never wore on the seal, but the same setup swapped into my third car was too tight and I had to get the driveshaft shortened a bit. You may find you can make some room by playing with the mounting points of everything in the car, but if not you will need the shorter driveshaft so that it doesn't fit tight against the transmission's tail and wear the seal and housing.
#8 | |
Thank you for the information. I am thinking about just going out and buying an ABS driveshaft and seeing if it will button up, atleast before I go cutting driveshafts. If somehow I can make the driveshaft that I have right now work but it's just a tight fit, will that mess anything up? I'm nervous that if it try hard enough to get in the driveshaft that I will end up getting that yoke stuck in tail end of the tranny, in turn making it nearly impossible to take out again. |
